Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Temperature Alarm My alarm is going off but the seal on the door is fine and the freeezer is not overloaded. I've unplugged the freezer and re-plugged it but the alarm keeping ringing.
  • wine244 May 07, 2010
    I have checked and there is no ice build-up inside the init. The fan is working. I've unplugged it again, let the door open for 5 minutes and re-plugged it. The alarm comes back on? The inside walls of the freezer are very cold, not warm.
    President:
  • 949 Answers
Can you look behind the food and shelves at the back wall near the bottom, if there is a frost build up on the back wall we have an issue with the defrost system, this would cause poor air flow and loss of cooling. I do not have your model number but I am assuming since it is a frost free unit it has an internal fan. If so is the fan running inside, can you feel air out the vent in the top? If not your fan motor may have gone out. The next thing to check is feel the side walls of the freezer, they should be warm. If they are not the compressor may not be running. Let me know the results of these questions and we can go from there.
Posted on May 07, 2010
Testimonial: "Still trying to work out the problems by elimination of various issues. Very good feedback."
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door left open for about 90 mins on freezer now red alarm light is on all the time?
Good Morning Martin, thank you for your post!
If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Oct 04, 2013 | Frigidaire FVE145FF Upright Freezer
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Frigidaire FFU20F9G (model FFU20F9GW3) temperature light is on
Several things could cause this. To check most things you will need to remove the back wall of the freezer to see the evaporator. It is possible the freezer is low on gas. If it is the coils will usually appear to be only half frosted or less. It is possible the defrost is bad ( I assume this is a frost free) In this case the coils will be totally clogged with ice and no air can circulate. If so you'll most likely have to replace the bi-metal... a circular looking part about the diameter of a quarter clipped onto the coil with 2 wires leading from it. This may also cause the fan to stop running from ice accumulation...or the fan itself could be bad which would also cause a partial meltdown. Unless the machine needs gas an appliance repair person will probably charge you around 100 bucks for most of these repairs..gassing it of course will be more and there is no guarantee how long the gas will stay in it as most leaks are difficult, if not impossible to locate. Hope that helps !
Dec 06, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
if the gasket is still sealing allaround the door then u shouldnt be losing any cold. try defrosting the freezer cleaning it out and firing it back up.
Dec 04, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
570 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
