Question about Craftsman Garden
Valve adjustment procedure for a 12 hp. Tecumseh ohv. The compression release is off.
  • 1129 Answers
SOURCE: I need to know the valve setting for a 12 hp tecumseh
If you are refering the valve lash clearance or gap the exhaust gap is .010" - .012" and the intake is .008" - .012 ".
Posted on Sep 18, 2009
  • 245 Answers
SOURCE: I have a mtd (Canadian Tire) Lawn Tractor, 13
Could be timing, but you didn't mention any repairs that could have gotten the timing off. You might check the gap of the points and the timing. The worst thing it could be is a valve problem. If the intake valve is leaking or not closing all the way it could cause backfiring through the carb. What did you mean when you said "fighting a compression stroke"?
Posted on Aug 29, 2009
Testimonial: "Hi. This is great! I have had no previous work done on the engine. When it is turning over it only cranks so far, then stops, even wiith a fully charg"
vincob
  • 718 Answers
SOURCE: how to adjust comp release on a briggs and straton
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Apr 08, 2010
  • 760 Answers
SOURCE: Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Posted on Jul 04, 2010
SOURCE: Poulan 42-inch Steel Deck 15 HP Tecumseh xl/c
i need a gas tank for it do u know were i can get one.Thanks
Posted on Sep 22, 2011
I have a 21 hp Briggs and Stratton model #331877, what are the valve settings?
Intake 003 - .005
Exhaust .005 - .007
Adjusted with the piston 1/4" past TDC of compression stroke for each cylinder.
Apr 10, 2015 | Craftsman Garden
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
Have a craftsman gt 5000 with a briggs 22 hp ohv els725 engine. the engine starts hard, then seems to act like its going to die, then i can partially choke it and it seems fine. then when its put under...
It could well be in the valves. The valves are adjustable on this engine and affect the operation of the built-in compression release. The release greatly aids in easier startup. Adjusting these overhead valves is part of the maintenance required for these engines. They don't have hydraulic valve lifters, so adjustment is required. Go to this page, scroll down to the bottom of it and find 'Adjusting Overhead Valves." There will be instructions and you can click on actual photos of the procedure to follow. I will also give you a Briggs engine chart (you supply the model no.) so you can determine what the valve lash will be for your paticular engine. Here they are, with the chart first, the directions on how to adjust your valves afterwards.
Find your engine in the OHV lists.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
And now for How to adjust those valves:
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
Jun 26, 2011 | Garden
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
18.5 HP OHV LT INTEK BERNING UP STARTER IT DOES NOT HAVE ENOUGH BALLS TO TURN IT OVER
If you have a good battery then the problem likely is the valve adjustment. I know it sounds crazy but if the valve lift is not set right it has too much compression. These engines have a compression release for when it is cranking to make the cranking easier. When the engine starts it goes off and runs normal. If you get that adjusted it will run like new. it is pretty cheap to have the shop do it too.
Jul 20, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I have a mtd (Canadian Tire) Lawn Tractor, 13 years old. It is powered by a tecumseh 4 cycle OHV 12 hp vertical shaft engine. When i went to start today, it was fighting a compression stroke, then popping...
Aug 29, 2009 | Garden
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
620 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
