Question about Garmin nuvi 200W GPS Receiver
Turn on shuts right off already tried to reset?
    President:
  • 1,851 Answers
The problem is either a dead battery - and the only way to know is to charge it for sure - in a wall charger. Many cell phone chargers etc will work- other wise - you must charge it in the car charger - this takes at least 20 minutes.
If your battery will not charge - I suggest you send it to Garmin for servicing.
Also a new Garmin 285WT is on sale at Tiger Direct dot com.
Gary
Posted on May 07, 2010
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Hpw to reset macbook pro
  1. Turn off your Mac (if it isn't already off).
  2. Hold down these four keys right after you press the power button: command+option+P+R (that will reset the PRAM).
  3. Keep holding down those four buttons until your Mac restarts and you hear the second startup chime.
May 28, 2014 | Computers & Internet
Shutting itself down
Make sure the charger is plugged in before attempting this. If already plugged in or same thing happens then you can try and follow the guide as below to do a hard reset:
http://www.mobicpc.com/how-to-hard-reset-archos-97-titanium-hd-to-factory-default-setting.html
If still not able to reset, poss hardware issue
Thanks
Oct 23, 2013 | Archos 97 Titanium HD 9.7" IPS Tablet
It just shuts off :(
replace Lamp Call Mats Electronics 1-800-628-1118
Feb 01, 2010 | Mitsubishi WD-60735 Projection Television
Hello, I have Sony KF50WE610. I have already
Blinks 4 times means a temperature error. Check the fans and if ok replace H3 board part# A-1405-433-A a small board located in the left side(when you are in the back of the TV).
Jan 03, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Razor shuts off by itself
your probly right.....its either corupt software of a battery issue....try the obvious first (remove and reinsert the battery if you havent already)....if that fails, try the master reset.
MENU > SETTINGS > INITIAL SETUP > MASTER RESET
**default code is 000000 (6 zeros)**
if THAT doesnt work, try a different battery. you can pick them up cheap if you dont have one lying around from www.amazon.com or www.shopmotorola.com
if thats not an option, try a master clear. if you dont want to buy anything, i would try this first. the master reset just sets everthing back to manufacturers default.....the clear DOES. you will LOOSE EVERYTHING INSTALLED ON THE PHONE MEMORY.
to do this, go to MENU > SETTINGS > INITIAL SETUP > MASTER CLEAR
**again, default code is 000000 (6 zeros)**
good luck :)
Jan 26, 2009 | Motorola Mobility RAZR V3
My daughters 1993 jeep grand cherokee laredo alrm system went off while she was in school and ran her battery down so we tried jump starting it and it will start for a few seconds then shut off, I reset...
I have a 95 Grand Cherokee, its got this built-in 'kill switch' (lol) that i had to figure out - the alarm wouldn't stop going off until i put the key in the driver door, then turned it Right-Left-Right...
Your probably already aware of this nuisance, but i thought i'd post it it just in case.
Dec 09, 2008 | 1995 Jeep Grand Cherokee
Mitsubishi WS-55807 television
this tvhas a built in safety feature, fuse, sometimes you can hear a faint popping noise when you turn the tv on and it shuts down. This feature was designed to prevent power surges from hurting your tv any more than it already is. You will have to have someone repair the small problem you have now and reset the tv. 10% of the time you can try holding doen the menu button for 10 seconds and/or unlpugging it for 4 hours to do a hard reset. This hardly ever works though. It will probably cost you about 200 to 500 to fix it. sorry
tom
Jun 05, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Sony nwz b105 mp3 player
try to reset the device
yet if its not starting contact nearest service center
Feb 02, 2008 | Sony NWZ-B103FBLK MP3 Player
Garmin nuvi 200W GPS Receiver Logo
339 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
