Savin 9927dp photoconductor ?
''replace photoconductor unit'' message came up on our Savin 9927DP.
I read somewhere that it can be reset instead of being replaced. If so, how is this done & are there any possible negative ramifications for resetting instead of replacing?
Thanks,
Rob M
  • 26 Answers
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
Posted on May 17, 2010
Photoconductor unit
what model machine and what do you want to know about the photoconductor unit
Apr 10, 2014 | Savin Office Equipment & Supplies
Savin 816 photoconductor troubleshooting
Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear the PM Counter.
Sep 01, 2009 | Ricoh Aficio 250 Copier
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Resetting the photoconductor unit
You need to enter service mode and the # is SP 5-912-1 set this to 0 (to get in to service mode press in sequence clear modes 1 0 7 and hold red stop for 5 or so sec. At the top of the screen should be direct SP highlight this and press the 59121 and it will take you right there.-Carl
Jun 28, 2009 | Savin 9935DP Laser Printer
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Savin 2527 indicates toner empty
i would suggest make sure the toner is the correct type, make sure when you install the cartridge it is tilted a little so toner will be towards the cap.
change your photoconductor unit.
Jul 19, 2008 | Savin Office Equipment & Supplies
Funtion problem
Sc 322 means there is a problem with the laser unit,and 99% of the time it is the polygon mirror motor within the laser unit. You have 2 options.Replace the entire laser unit which is in a neat little black box and is relatively easy to replace. Better yet,merely replace the mirror motor which is enclosed within the laser unit. But one or the other must be replaced as there is no adjust/oil/clean/tinker/fudge to be done. I wish I had better news but really the news aint bad and the advice is free so if you have to get "copier dude" to come out he/she wont try to hose you !!! Well they might try,but YOU know better. :-) hope this helps,take care. .......spinal.......
Mar 25, 2008 | Office Equipment & Supplies
SAVIN 3515MF
open the right door. Open the front cover. Remove the toner assembly, not just cartridge. Unplug wire, pull out.
Mar 12, 2008 | Office Equipment & Supplies
432 people viewed this question
jasbo
jasbo
