Question about Amana Heating & Cooling
An amana 15 seer was in stalled in my house, the air is blowing really loudly from the vents, which my previous system did not do, when thermostat is on rather than auto or cyclicling it is better but still too loud (strong) to be comfortable, what to do???????
    President:
  • 949 Answers
The blower on the inside unit is adjustable, but it has to be set for the proper temperature drop on the A/C coil.
What I am getting to is if the installer did the job right and set the blower speed, it is going to have to stay that way or the you will have freezing problems. If he just set it to high speed you may be able to lower the speed so it is quieter. Saying that you would need a professional to take temperature readings to adjust properly.
Sorry it is not an easy answer here. Let me know if you have more questions.
Posted on May 06, 2010
Amana heat pump 13 seer split system when in heat pump mode once the thermostat is satisfied the head pressure on the high side shoots up to 600
410 a runs at a much higher pressure then r-22. that is still very high. it would take a temperture over 150 degrees to produce it on a idle system.
Feb 15, 2015 | Amana 3.5 ton 13 Seer Split Heat Pump...
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
Goodman SSZ140481AG, what is it? is it 14 seer or 15 seer? I paid for 15seer but the unit has a decal on it reading 14 seer??? Thanks
It is federal law that each new piece of A/C equipment have the yellow SEER rating.
The higher the SEER, the less electricity the system uses to operate.
You need to follow up since it appears your contractor installed a less efficient/expensive system than what you paid for.
Good luck.
Sep 15, 2013 | Goodman CACF048B2A Air Conditioner
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Replacing HVAC
Check with you energy company. We found out after we replaced our unit, that if we went with a particular seer we would have qualified for discounts to our bill as well as government incentives and additional discounts. It will keep you cost reasonable and your energy company will give you an honest answer to which will be best for your specific house layout as well as your electrical connections that will need to match up with your new unit. Hope this helped some.
Apr 12, 2013 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Amana central heat and air unit use to blow cold air through all the vents. Now the 2 hardest blowing vents close to the air handler barely even blow out cool air while all the other vents still blow very...
Visually inspect the duct run connections to the main trunk. It is possible that they have loosened and are losing air under the house. Also inspect the duct runs from the trunk connection to the vent connection. You want to check for any damage or other failure. It is rare to find dampers in individual runs in residential duct systems; however, it is another possibility.
http://www.youtube.com/watch?v=28ru4mlFMpI
I hope you find this information helpful. Good Luck in your endeavor! :-)
Mar 11, 2010 | Heating & Cooling
Amana ultron 12 seer 2 yrs old compressor does not work blows cool air not cold
is it a split system? majority of problems, lets say 95% occur during install, u may have a leak! A pinhole at that, but maybe installer missed it, your out of labor warranty, call a 3rd party contractor and have them inspect it!
Aug 06, 2009 | Amana Comfort Zone 12M32PBEH Air...
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Heating & Cooling Logo
16 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
