Question about SanDisk Sansa e250 MP3 Player
I shut down the computer while charging my mp3
I shut down the computer while charging my Sansa mp3 player and it is showing disconnected now. How do I get the screen to clear so I can continue charging? Just let the battery get low and die? Or plug it back up to my usb and continue? Please help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
Posted on May 07, 2010
My sansa willo not charge. It keeps shutting down
try checking every five minutes and turn it on.
Sep 29, 2009 | SanDisk Sansa e250 MP3 Player
Sansa Clip 1G stops charging after a few minutes..
Make sure the hold/lock is not engaged first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 26, 2009 | SanDisk Sansa Clip MP3 Player
SANSA CLIP CHARGING FOR THREE HOURS SHOWING 1/4 CHARGE
Make sure the hold/lock switch has not accidentally been engaged first.
-Tha Mp3 Doctor
Mar 25, 2009 | SanDisk Sansa Clip MP3 Player
Battery won't hold charge very long
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Won't work after charging
-Tha Mp3 Doctor
Nov 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
It won't charge completely
Make sure the hold/lock is not engaged. You may have a hardware issue, but just to rule out the possibility:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Nov 19, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Can't access on the computer and doesn't turn on when disconnected
I downloaded and reinstalled the latest version of media player form windows. problem solved. thanks anyway.
Trent
Jul 25, 2008 | SanDisk Sansa MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
Wont Charge
-Tha Mp3 Doctor
Apr 30, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
