Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
Top 4 inches of screen is dark shaded compared to the rest of the picture and the right upper corner holds the picture for 10 or 15 seconds after the show has moved on????
  • 1 more comment
  • epm369 May 07, 2010
    NOT SURE WHAT HAPPENED WHEN i POSTED THIS BUT THE problem is on a sony bravia KDL-46s5100 TV not the Akai sorry not sure how that happened
    it is actual a sony bravia kdl-46s5100 tv not the akai I messed up when I posted thanks for any info
    1 yr warranty only what should I look for got it apart
  • Akai Master
  • 11,800 Answers
The image processor has died. Unfortunately finding a replacement part will be almost impossible - they weren't sold in retail outlets.Add to that the fact that your tv is an old model. Try sites that sell second-hand parts.
But in my opinion it will be cheaper just to buy a new monitor with a separate tuner.
Posted on May 07, 2010
  • Azrael SRL May 07, 2010
    Another story altogether -  this Sony is a new tv from a big manufacturer with a lot of dealers. It will be relatively easy to fin the part.
    But since this is a recent model it may still be in the 2 year manufacturer's warranty period and in that case it should be fixed by them for free .
    Unless you can see a failed capacitor or some other burned part, there isn't something to see - when a chip dies it doesn't show it physically, only thru testing you can find that for sure. Check the voltages on the main board.
    BTW - 1 year ? That's odd, a brand new electronic device has , by european law, a 2 year warranty period. Was it a refurbished/ off case part ?
  • Akai Master
  • 12,061 Answers
Http://www.manualzone.com/ShowProductsForModel.do?model=LNG1.Dyn.M84635494KYWRDS_Akai_CFTD2011_CFTD2011_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
http://www.scribd.com/SynsMaster-Tr-Manual/d/27109207
Ok one of your Boards has gone faulty, But you see, even so, one, MUST start, troubleshooting in the right place. no matter what the problem. The power supply, FIRST, as, if, that isn't right, nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Akai, in your case, contact a local or head office, and ask for a referral, to an Authorised service Center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else. Anyway thats my 10c worth.
Top left and right corners are dark on my 55 inch seiki tv
The picture tube could be getting old.
Normally this effect can also be due to alignment with the magnetic meridian.
You can try to de-gaussing with a high voltage gun.
http://www.repairfaq.org/sam/crtfaq.htm
see section
CRT Age Resulting in Dark Picture
Aug 20, 2016 | Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Black shade corner lcd tv screen
you'll more then likely have to replace the screen. laptopscreens.com is a good place to buy a replacement.
Jul 30, 2013 | Sony VAIO C Series Notebook VPCCB17FXW
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Feb 19, 2010 | Nikon COOLPIX P80 Digital Camera
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Convergence problem
no u cannot do anything on ur own u need to call an expert,
Apr 04, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
