Question about Robin Subaru R1100 Portable Power 1100 Watt Generator
Trying to find a part
I have a small Fuji-Robin gas water pump
Mustang pump ECO25 GR 5023
Engine Family 2FNXS.D254TA
Engine Serical # ECO25G-24-811282
25CC Cubic Centimeter
Need a diapham which is inside carbuerator
Have spent hours trying to find a sight for help.. this is a long shot. You probably can't help me, but worth a try. Thanks
  • 905 Answers
Parts Manual is available at http://www.robinamerica.com/media/manuals/128982825630877500.pdf
Though your exact model is not listed specifically, the same part number is used on both the 22 and 25cc engines across all listed versions. Worth a shot to call them up with part number and try to order it.
Oh, your part # is 524-60010-40, They can be contacted at http://www.robinamerica.com/contact.aspx and they even have an 800 number.
We can help you, just had to try. Hope it works out for you.
Posted on Jun 12, 2010
ENGINE RATTLES AFTER PUSHING THE GAS
Poss water pump bearing, grab the water pump pulley and see if it moves side to side and up and down, if so the bearing is gone.
Jul 19, 2012 | 1991 Ford Mustang
2002 mustang the motor turns over and it gets gas but it wont run gas had water and we empty it and put new gas but it want run
Fuel system may be contaminated. Even if you drain tank it will have water in the injectors. Take a can of starting fluid, have some one turn over engine. Spray a small amount in throttle body. IF engine starts suspect water still in injectors. You may have to repeat several times to clear out. ALSO there is a small valve on fuel line. IT is where you would hook a fuel pressure gauge. YOU can bleed the water out at that point. You can open valve and turn key on and off several times, place a rag over check valve as fuel will spray out! Close valve try and start car
Feb 16, 2011 | 2002 Ford Mustang
I have a 2000 mustang that will not stay running,,, it was running fine, i parked it for two months in the cold and didnt start it up, when i did... it wont run if u give it gas however it will set and...
I would run the fuel pump for a little while with the fuel line disconnected from the engine into a gas can . Although you might have changed everything you might still have residual water in lines or motor. I would still put dry gas in the tank
Jan 31, 2011 | 2000 Ford Mustang
I have a 2000 ford mustang that needs the water pump replaced. I have removed the bolts to the water pump but the water pump will not come off the engine. what do i do?
most likely heat and corrosion has welded it to the engine. Take a small rubber mallet and strike it all around the pumps outter edges. It should come off.
Oct 11, 2010 | Ford Mustang Cars & Trucks
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
Need to know what the in and outs are on the water pump.5.0 eng.
Viewing the Mustang from the front, the water pump turns to the left. (So does the harmonic balancer below)
The 3/4 inch, and 5/8 inch nipples on the water pump?
Heater core that was removed. IN at the top, OUT at the bottom.
Oct 13, 2009 | 1985 Ford Mustang
Aloha,have 98 base mustang, overheating after many replacements
i would change the water pump and check for plugs in the heater core
Sep 26, 2009 | 1998 Ford Mustang
Open Questions:
Robin Subaru R1100 Portable Power 1100 Watt Generator Logo
333 people viewed this question
Top Robin Subaru Electrical Supplies Experts
Jim Parker
Jim Parker
John Trevino
Bill Boyd
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
