Question about Whirlpool Dryers
Whirlpool duet wed9600tao will not turn on. power panel does work
Whirlpool duet wed9600tao power comes on but dryer will not engage with start button. you can hear it click but not come on
  • 4 Answers
SOURCE: not getting any power at all from whirlpool duet dryer gew9200
When we got ours it had the same problem. A service call would have taken days so I simply unplugged the unit (safety first!), and removed the top (a number of sheet metal screws). In the front left I noticed a couple of "ribbon" cables and one was hanging loose (obviously NOT connected). I looked around and located where it was supposed to be connected and snapped it in. Plugged the unit in and Voila! all worked. Unplugged unit again, put the top back on and everything has worked since then.
ONLY DO THIS IS YOU HAVE THE TECHNICAL EXPERTISE AND MAKE CERTAIN YOU UNPLUG THE UNIT BEFORE ANY ATTEMPT.
Posted on Nov 23, 2007
  • 262 Answers
SOURCE: my dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Posted on Dec 29, 2007
dmftrucker
  • 1922 Answers
SOURCE: I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Posted on Nov 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool duet sport dryer gives F02 code. I
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$@&^$
Posted on Sep 21, 2010
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
I have a Whirlpool Duet dryer, model # WED8300SW2 and the power button will not come on. Can you help?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet dryer will not start , lights come on but will not start none of the buttons work
heatman101
Apr 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool wed9600tao will not get hot power will come on but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 14, 2010 | Dryers
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Gas Dryer won't start
Did you take the shipping blocks out? They are inside the machine. You will need to remove the access cover on the back and look in, you cant miss them. Good luck
Jul 26, 2009 | Dryers
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
DUET Dryer M# GEW9200LQ0 - Not cuttinh on
coasty...I'm a believer in starting small and going bigger. First, turn off power at the breakers and then back on. You must do this on both sides of the line. If this resets everything, you're good. If not, check the rest of the wiring. Still no, then you're going to need that circuit board.
Dec 08, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
185 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
