Question about Race Face Evolve XC Mountain Bike Crank - Triple
Brand new Race Face Deus 2010, chain skips
This morning I installed a brand new 2010 Race Face Deus crankset on my Gunnar Rockhound as per the manufacturers instructions (regarding spacers, chainline, etc.) I also installed a new SRAM 9 speed chain (PC 971, with power link). The cassette is Shimano XT (M770), as are the shifters and deraileurs.
When I took the bike for a ride on some local trails the chain started to skip on the chainrings. It happens on both the middle and inner rings. It happens specifically when I'm pushing hard in bumpy sections, especially technical hills. It even threw the chain a few times. Needless to say, I'm frustrated that my brand new equipment is not working! The shifting is perfect and very quick, and the cranks feel great otherwise.
    Brigadier General:
  • 8,546 Answers
A new chain and old cassette will do exactly what you're experiencing. The chain skips over the teeth because the profiles of the teeth don't match the distance between the links on the new chain. Look at how the chain sits in the cogs. It should sit in the bottom of the space between each tooth and if you push in on one link the others should not move.
Posted on May 07, 2010
I want to put the best oil brand and filter in my car..want to get some suggestions on which type of oil and best brand...thanks
Hi Duke:
I ran Castrol in my race cars for years and never had an engine failure that would be associated with an oil problem.
That's not to say it's better than any other brand.
Your auto parts and supplies store... Napa, Lordco ???
will coach you on the appropriate filter for your specific application.
Cheerfuls.
Aug 26, 2015 | 2010 Infiniti M 35x
How do you take the crankset off of a 2010 kona blast
The problem is not in the crankset, its in the freewheel or cassette in the back wheel. The crankset is always free, and doesn't have anything to do with the skipping. Take your back wheel to the local bike shop, as it takes special tools to remove the freewheel.
Oct 12, 2014 | Cycling
Mt999 chainsaw. Brand new. Not cutting through wood although blade rotating. Just seems to be burning wood.
If it's all brand new, then sounds like you have the chain on backwards. The angled parts of the cutters should face forward while on the top of the bar.
Mar 16, 2014 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Just purchased bike and chain skipped under load
very likely that chain links not "fitting" cog teeth . if both chain and cogs are brand new, then skipping should never happen. more often than not, a repair would require both new chain and new rear cogs, and possible new fron t chain wheel. all depends which item are worn. I would probably get a new chain firstly, then see if this fixed the problem. nigel
Jul 06, 2012 | Specialized Hardrock Pro Disc
My crankset is loose and i get it tight could you tell me the promblem.
Did someone try to fix your bike for you? Has the crankset been removed?
Does the crankset loosen as you ride it? How do you retighten it?
How far (left and right) do the peddles move when you wiggle the
crankset? If you had a set of ball bearings without a bearing race
(which holds the ball bearings) on both sides of the crankset, then
you may have lost the balls when it became loose the first time. In
that case, simply tightening the crankset will not solve the problem.
Aug 21, 2011 | Columbia Sportswear Columbia Trailhead...
Right side pedal is "wallered
That would depend on the brand and design. A sprocket is literally a gear. A crankset is the combination of the crankarms and mounted gears. Bottom brackets join them within the frame.
http://en.wikipedia.org/wiki/Crankset
http://www.sheldonbrown.com/brandt/stuck-pedals.html
Pedals are replaceable.
A Bicycle Shop could help you decide what you need and select the proper size(s).
Mar 30, 2011 | Cycling
The plate on my e-type is bending when pulling the line, making shifts unprecise. What do I do wrong ?
I am not quite sure what you mean by plate, but if you mean that the whole derailleur assembly is moving under tension, you have to make sure that the bottom bracket cups are tight.
To do this will require removing the crankset and following the installation instructions listed here. follow the directions for your brand of crankset (if Shimano, then Hollowtech II) under the bearing installation heading.
Mar 16, 2011 | Shimano Xtr Fd 970 E Type
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
New kmc 10speed chain skipping over a newer durace cassette
If you replaced the chain yourself , you may have left it too long. With the chain on the biggest cog on the rear and the biggest cog on the front , pull the two ends of the chain together and see where they will link up. Leave another two links in the chain and it should be the correct length. You may also have the wrong chain for the bike. Also carefully check each tooth on each cog front and back for wear. Also check the idler wheels in your rear derailleur.
Mar 29, 2009 | Cycling
Race Face Evolve XC Mountain Bike Crank - Triple Logo
140 people viewed this question
Top Race Face Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Race Face Cycling Expert? Answer questions, earn points and help others
