Question about RCA RTD300 DVD/VCR Home Theatre System System
Connecting RCA RT2770 to PC
Can I use RCA RT2770 home theatre system as PC speakeers? I can't figure out how to connect them. System was a refurb I bought from WOOT while still under anesthesia following surgery... Dumb, I know.....
Thanks
  • 4,234 Answers
Yes. Take the output from the sound card and connect it to one of the tape inputs. Note: you should use the "line out" jack for this.
Dan
Posted on Mar 27, 2008
  • David Barkhouse Oct 05, 2010
    Or, if your sound card on your computer has a connector labelled as "COAX" you can plug it into the matching one on the receiver, or, if your sound card has the "Digital Optical Out" option (such as my sound card has, though the receiver I'm using for my computer is NOT the RCA RT2770, but rather a Yahoo! YHT400 that only has the analogue inputs) Anyway...the RT2770 *should* work with your sound card, if you make one of the connections described by either Abrsvcs or myself. The connection Abrsvcs mentions requires the use of a "3.5mm to RCA" patch cable. Which, until about 3 years ago, I didn't know there were commercially available ones, and would make my own using a cable from an old pair of headphones and the female end of an RCA extension cable...
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
RCA RT2770 Home Theatre Receiver
The power supply may have failed
Jun 18, 2013 | Audio Players & Recorders
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Connet to pc
Well, I would have to know what connectors your sound card and home theatre system have. If you dont have a sound card, get a headphone/3.5mm trs plug to stereo rca plug adapter usually available at your local radio shack or walmart, and connect to the red/white rca plugs on your reciever. If they have other connectors(your sound card/ home theatre system) you might try coaxial digital audio-S/PDIF or optical S/PDIF.
Dec 25, 2007 | Durabrand HT-3915 System
RCA RTD300 DVD/VCR Home Theatre System System Logo
212 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
