Question about Keurig Elite B40 Coffee Maker
The shield on the upper section that moves down over the bottom is broken. is there somewhear to get parts?
    Champion:
  • 213 Answers
No problem here ya go!
http://iwantsweetdeals.com/ We have all Keurig parts
Posted on Jun 14, 2010
One of the heater gears ( shield ) is continuously broken several times
take out the gear which drives the broken gear then replace the broken with a new gear, check manyally driving the gear,which part or gear causing resistance in the smooth operation, replace the faulty part/gear.lubricate moving parts.
Jan 12, 2011 | Canon NP 6050 Copier
Need diagram 2001 vw new beetle fuse panel. When I bought it did not have panel cover........thanks! problem with washer pump book says #1 10 amp small fuse and #24 20 amp no where on fuse panel says #'s
The #1 fuse is in the upper left corner of the fuse panel, actually its the top fuse in the third row down, but row No. 1 and No. 2 do not have any fuses in the upper left corner. There are a total of 23 fuses in the upper most section. Fuse #24 is the first fuse in the lower section of fuses (upper left corner of that section as well.
The block diagram for the fuse panel is also contained in Section 3.2 of your Owner's Manual. The fuses are numbered in each section from top to bottom starting in the upper left. Fuses 1 thru 23 in the top section, fuses 24 thru 44 in the bottom section which consists of three columns.
Oct 28, 2010 | 2001 Volkswagen Beetle
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How to 1998 Taurus altenator R&R
please rate highly if this helps
Generator 3.0L (2V)
Removal
  1. Partially raise the vehicle on a hoist. Refer to Section 00-02 .
  2. Remove the right front wheel. Refer to Section 00-02 .
  3. Remove the lower fender splash shield retainers and position the shield out of the way.
  4. Lower the vehicle.
  5. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  6. Remove the power steering line bracket and heater hose support bracket from the generator.
  7. Remove the upper generator bolts.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Disconnect the right hand stabilizer link.
  15. Lower the subframe to provide clearance.
  16. Remove the generator.
Installation
  1. NOTE: Do not tighten the lower bolt.
    Install the generator and the lower bolt.
  1. Raise the subframe and install the subframe bolts. Tighten the bolts to 90 Nm (66 lb-ft).
  1. Connect the right hand stabilizer link and torque to 47-62 Nm (35-46 lb-ft).
  1. Remove the adjustable stand.
  1. Lower the vehicle.
  1. Install the upper generator bolts and tighten them to 25 Nm (18 lb-ft).
  1. Install the power steering line bracket and the heater hose support bracket. Tighten the nut to 20 Nm (15 lb-ft).
  1. Install the accessory drive belt. Refer to Section 03-05 .
  1. Partially raise the vehicle.
  1. Tighten the lower generator bolt to 25 Nm (18 lb-ft).
  1. Connect the generator electrical connector.
  1. Install the battery positive B + cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Install the generator splash shield.
  1. Install the fender splash shield and the retainers.
  1. Install the right front wheel.
3.0L (4V)
Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 14-01 .
  1. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  1. Remove the power steering line bracket and heater hose support bracket from the generator.
  1. Remove the upper generator bolts.
  1. Remove the right front wheel. Refer to Section 00-02 .
  1. Remove the lower fender splash shield retainers and position the shield out of the way.
  1. Remove the generator splash shield.
  1. Raise the vehicle.
  1. Disconnect the electrical connector and remove the battery positive cable from the generator.
  1. Remove the right subframe bolts.
  1. Remove the lower generator bolt.
  1. Lower the subframe to provide clearance.
  1. Remove the generator.
Installation
  1. Install the battery positive B+ cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Connect the negative battery cable.
3.4L (4V)
Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the right side cowl vent screen. Refer to Section 01-02 .
  1. Raise the vehicle and remove right front wheel assembly. Refer to Section 00-02 .
  1. Remove right tie-rod. Refer to Section 11-02 .
  1. Remove accessory drive belt (8620) from generator. Refer to Section 03-05 .
  1. Disconnect electrical harness connector and output terminal wiring.
  1. Remove nut and position engine control sensor wiring (12A581) out of the way.
  1. Remove the two bolts and one stud bolt.
  1. Remove generator from vehcile
May 12, 2009 | 1998 Ford Taurus
How do i remove the alternator in a 2001 sebring convertible?
2.7L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable from the shock tower Accessory belt splash shield and loosen the belt Alternator electrical connectors A/C pressure switch and clutch electrical connectors Engine oil dipstick Alternator
To install:
  1. Install or connect the following:
    Alternator and torque the bolts to 40 ft. lbs. (54 Nm) Engine oil dipstick tube A/C pressure switch and clutch electrical connectors Alternator electrical connectors Drive belt and splash shield Negative battery cable
  2. Raise vehicle and support.
  3. Remove the accessory drive belt splash shield.
  4. Loosen the accessory drive belt.
  5. Remove the lower mounting bolt.
  6. Lower the vehicle.
  7. Remove the electrical connections from the alternator.
  8. Disconnect the electrical connector to the A/C pressure switch and A/C clutch.
  9. Remove the engine oil dip stick.
  10. Remove the 2 upper mounting bolts.
  11. Remove the alternator.
To install:
  1. Install the alternator.
  2. Install the 2 upper bolts, but do not tighten.
  3. Install the engine dip stick tube.
  4. Connect the A/C pressure switch and A/C clutch electrical connectors.
  5. Connect the electrical connections to the alternator.
  6. Raise vehicle and support.
  7. Install the lower bolt. Tighten bolt to 40 ft. lbs. (54 Nm).
  8. Install the accessory drive belt.
  9. Install the accessory drive belt splash shield.
  10. Lower the vehicle.
  11. Install the 2 upper mounting bolts. Tighten bolts to 40 ft. lbs. (54 Nm).
  12. Connect the negative battery cable.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 28, 2009 | 2001 Chrysler Sebring
Not fully agitating
2 things
First is that I assume this not to be a 1 piece agitator. If it was the whole thing should turn back n forth Make sure its top (nut) fastner is tight. Usually just push down slightly and turn Clockwise.
A sectioned agitator has a lower section separate fro the upper. The lower can be attached to the agitator shaft and will move back n forth but the top has teeth that engage 1 way and allow slippage when the agitator comes back the other way. This "ratchet" action (some whirlpool older models that i have seen) if it has teeth ground off or grease build up under the teeth can cause them to stop agitating and just kind of sit there.
Drain and remove the clothes,
Take the top by hand and try turn it back n forth see if bottom moves. If the top is slipping and the bottom stays put remove the top nut (turn Counter Clock Wise) and try remove the upper section. If you can get it off you may be able to see why its not turning, and get the part to fix it.
Please let me know if this helped you. Rate me with as high a mark as you can. thanks and good luck.
Apr 02, 2009 | Washing Machines
Dyson dc07
You can take the clear part off pretty easily, but the upper cylcone section is held on by three star screws on the upper -handle end. After taking those off, the handle comes off and it has a long stick that runs down the center of the cylinder. There are now 8 cyclones facing you. Clean them however you want, but I couldn't get it broken down any further. There are three more star head screws down the center, but after taking them out, I couldn't get the purple upper piece apart from the lower, grey piece. So, I just kept it all dry, pounded on it with a rubber hammer to break the crust off everything, ran a screw driver into each of the cylclones to clear them, and put it back together. Make sure you put your hand down at the bottom when you're trying to line up that stick to put the handle portion back on the whole assembly. If it doesn't make it back in it's little home, it won't empty correctly.
I hope this helps.
Joe
Apr 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Keurig Elite B40 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
