Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Blocked mac adress
Hi! i blocked my Mac adress at the router, and now i cannot connect to the internet. I tried to reset the router by holding the reset button for 10 sec, it didnt help. I even cannot open router set up page 198.162.2.1. What shall i do? I know my Mac adress i it is can help? Shall i try to change my Mac adress? Could you plz recommend smth, but smth more simple, co i am not ood at PC. Thnkx Amrita
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 15 Answers
Hey,
Try holding the reset button for a little longer, say for 30 secs.
Keep an eye on the power light and the power light on the router should start flashing.
Than release the button.
Posted on Mar 29, 2008
SOURCE:
Netgear N300 Firewall setting
wait you using DHCP? What's to stop the computer from releasing the dhcp lease and obtain a new IP besides the 192.168.0.5 that you are blocking?
Apr 11, 2017 | NetGear N300 Wireless Router
I have a acer tablet and a netgear router and lost my pass word how do i get internet on my tablet
If you lost the password for the wifi connection then you can just log into your router by going to your internet browser and typing 192.168.0.1 or 192.168.1.1 in the adress bar. The username is admin and the defult password is password or 1234. Under wireless settings you can change or remove your wifi password.
If you have changed your log in password for the router then you will have to reset your router. To reset your router to factory defaults, use a pen or paperclip to press and hold the Reset button for approximately 10 seconds until the Test light blinks. Release the button and wait for the router to reboot.
Let me know how this goes and if you have any further questions.
Aug 09, 2011 | Computers & Internet
It is blocked domain by http://block.opendns.com how can i by pass that block
Hi,on the back of your router or the very bottom,you will see a reset button.Press that and hol for about 10 seconds.Make sure you have the IP adress for the router,as this procedure will rest it back to default.
Feb 22, 2011 | Computers & Internet
Newbie on this I added MAC adress
Reset the router and start all again. look for a little hole and in the hole should be the reset button, with power off, reset it and do it all again.. this time properly..
get your manual for a how to do it below. http://www.retrevo.com/samples/Zhone-Router-manuals.html
Mar 06, 2010 | Zhone (6218-I2-200) Router
I seem to be haiving a conflict with the Time warner cable modem and my router, web pages will not display
The cable modem uses an ethernet connection to the router. Open the router and check the status, if you see the time warner ip address in the status page of the router, then you have internet connection.
Jul 11, 2009 | NetGear WGR614 Router
Netgear DG834Gv3 ceased to get internet connection.
Hello!
Hopefully if you try the following steps, you might be able to get to the problem.
Troubleshooting Steps
  1. Disconnect the router, and make a call with your telephone. If this does not work, contact your phone company.
  2. Reconnect the router, checking that all cables attached to the router and computer are secure.
  3. Check that the WAN light is green or blinking green. This may take several minutes after connecting or rebooting the router. If the WAN light is off or blinking yellow, contact your ISP.
  4. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual.
  5. Check if the LED on the Ethernet adapter in your computer is lit. If it is not, then troubleshoot the adapter, do not continue this document.
  6. Power off the router.
  7. Power the router on again.
  8. If you still cannot log on to the router, then do a hard reset on the router, as described below in reset router.
  9. If you still cannot log on to the router, try to get assistance from Netgear at www.netgear.com.
  10. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 14.)
  11. If a dynamic IP address is discovered, go to Step 15.
  12. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 15.
  13. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 15.
  14. If the smart configuration utility does not find an IP address:
    1. Power off the router.
    2. Power on the router.
    3. Go back to Step 10.
  15. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access!
  16. If the page does not display in a minute, you may need to do something called MAC spoofing, which I listed below.
  17. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the router and computer, in that order. Wait for the router to completely reboot before starting your computer.
  18. If the router's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are greyed out, then settings for a non-dial-up connection are being used.
Reset for routers with reset button on back panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
MAC Spoofing
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router.If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password (or 1234) for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
I tried to get everything together to try to help you out.  Hopefully this stuff will get you online!
Ken
Jan 06, 2009 | NetGear DG834G Router
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
Resecure network
first enter the router ip adress in iternet explore. You will need to know the username and password to change the setting for you router.
Dec 30, 2008 | Buffalo Technology WHR-G54S Wireless...
No internet when using router
Your modem has already registered itself with the MAC address of your computer, so it doesn't recognize the MAC of your router. In cases like this you have two options:
  1. Configure your router to clone the MAC of your computer
  2. Connect the router to your modem and do a soft reset so the modem registers itself with the MAC of your router.
Clone MAC - Go to your routers Admin web interface and on the main page you should see the "Router MAC Address" section at the bottom. Select "Use Computer MAC Address" and click "Apply" and your router should reboot and you'll be back in business.
Soft Reset
- Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the Reset EMR button on the modem
  4. plug back in the power
  5. count to 30 while holding the Reset EMR button (the modem should be blinking a lot)
  6. release the Reset EMR button and see what happens.
Jul 07, 2008 | Computers & Internet
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
75 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
