Question about Insignia 42" LCD Flat-Panel HDTV
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
  • 736 Answers
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
Posted on May 06, 2010
My tv is 1080p, but when I turned it on it says it's only 720p..
Your tv may be matching the source resolution. If your BluRay player, Cable Box, etc. is set to put out 720P, the TV will not / can not magically make it 1080i or 1080P. Otherwise, you should check the Menu for Picture settings and make sure it is set to 1080i or 1080P so that it is displaying the highest resolution possible.
Feb 25, 2015 | Televison & Video
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
Shows 720p but should be 1080p seiki se24ft01
This will be ether the zoom button on the remote or If you go onto the menu screen settings
Jan 04, 2014 | Seiki 24" Class 1080p 60Hz LED HDTV...
No signal on tv and mode not supported via hdmi cable
Connect your PS3 to your tv using a normal AV cable. Check some Display settings like 720p or 1080p. I've your TV is 720p, 1080p probably wont work.
I'm not sure of this all, but its worth a shot.
Sep 23, 2011 | Sony Playstation 3 (PS3) Console
HI...HOW DO I CHANGE MY TV FROM 720 TO 1080?
U talking about tv show broadcasting in 720p,u wanted to changed it into 1080p.U can't do this,u only get what the tv stations modes,what ever modes they put out only.Put out 720p u get only 720p,if put out 1080p u get 1080p only.
Jun 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My ps3 wont show up on my tv screen it is a 42 inch plasma it will not show up it keeps saying invailed format what do i do?
Your 22 monitor is set up (most likely) with a max resolution on 1650x1050 and you ps3 stays set to that even when you use it on your dads 1080p TV (1920x1080) and since your 22 in monitor is a non-standard resolution (in the TV world that is ) ie 720p = 1280x720 and 1080p = 1920x1080 it has to adjust to the closest resolution (your ps3) but sometimes the auto switching of resolutions doesn't work like it should..it just doesn't work sometimes. I suggest that when you take it to your dads you adjust the resolution to 720p ahead of time (a resolution both the 22 monitor and tv should be able to handle ) and when you get to his house it should work at least enough to see everything and then when already there you can adjust up to the higher 1080p (1920x1080). Then adjust back to 720p before you go home again. Sorry for the long winded post.
Here is a link to resolutions explained in case it helps.
http://en.wikipedia.org/wiki/File:Vector_Video_Standards2.svg
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I bought an insignia 26" 1080p yesterday and the display shows that the tv is currently showing the picture at 720p. How can i adjust this so that it is 1080
Generally speaking, your TV will display the signal it receives. DVD player output, for example, is 480p, but an upconvert DVD player can output the signal at 720p or 1080p. You should adjust your components (e.g. cable/satellite box, DVD/Blu-ray players, etc.) to the desired compatible output.
Jun 15, 2010 | Insignia 42" LCD Flat-Panel HDTV
I had ps3 hooked up to 720p tv then hooked it up to 1080p moniter now it won't show a picture on 720p tv
you have to switch it back to 720p mode before disconnecting it from the 1080p television. If you're using HDMI, and then switching back to the a/v connectors, then you have to switch the output settings of the ps3 from hdmi to a/v as well.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
I can't get the 1080p resolution to my insignia tv. Anyone can tell me how to do it pleaes?
that's because the TV's are ahead of the technology. Cable TV does not broadcast anything in 1080P yet;
Feb 02, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Insignia 42" LCD Flat-Panel HDTV Logo
738 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
