Question about Insignia IS-LCDTV32 32 in. Television
Hard starting when it starts ok it did this about 10 times now it
Dose not turn on
  • 175 Answers
Check caps in power board look for bulged caps and replace, remember to unplug it for 1hour before playing with it:)
Posted on May 07, 2010
2003 silverado duramax shut off on me replaced the filter and reprimed still wont start the pump makes a little noise when i turn the key but only lasts about a 1/ 2 a second need help checked the fuel...
Its hard to say for sure .It could be the pump there olny good for 10 years or so depending on how much you drive it
It could also be a wireing or connection problem to the pump they have upgraded the wireing .
But it could also be the oil pressure sending unit .Chevy uses it as a back up for the relay in case the relay gose bad while driveing the oil pressure unit will energize the fuel pump to keep it running .
Dose it or did it crank for a long time before it starting before it wouldn't start anymore
Mar 16, 2015 | Chevrolet Silverado Cars & Trucks
Disable passlock system
You are out of luck. If you are not a licensed locksmith or automechanic, you cannot get that information.
Dec 02, 2013 | Cars & Trucks
My battery takes a charge but then drains right away.
OK so you have a simple problem so we start with Start and rum to 1000 rpm turn on your lights (main beam) then let it back to idle (dose the lights dim) if no ok NOW go to the battery and check the Pos and Neg terms when you start do either get warm,
As the problem is either bad gharging /or the battery has 1 or more sells down which makes the battery 10 volts and that wont turn the engine over so WHEN YOU NEXT START THE ENGINE RUN FOR 5 Minutes at 1000 rpm and then turn it off then remove the EARTH lead on battery .
Tomorrow re fit the term and try starting if it starts its a dead short like the alternator when stopped will return feed and cause your problem But if it dont start then with the earth lead off the battery has to be replaced ...
Let me know how you get on .
Ron
Nov 30, 2010 | 1992 Cadillac Eldorado
I have a 96 T100 and I would like to know how to test the Brake Power Booster
if the brake pedal gets hard then the bosster is defective, u may also hear a hissing noise from under the dash.
Nov 12, 2009 | 1996 Toyota T100
My car starts once then wont start again. Its a 92 Subaru. We tested the starter and it tested fine. Could it be the armiture?
What dose it do after starting then you turn it off whet dose it do /how and wheat type of sound dose it make ,,dose it just go clonk and nothing else/or dose it turn over slowly and dont fire Iwant to get all information before stating the problem.
If it tested ok then the starter should be good
Let me know how it sounds Ron
Oct 02, 2009 | 1992 Subaru Legacy
Starting problem on my audi a6 2.8 quattro,,, i need help
Sounds like the gas presser valve or weak fuel pump. When it dose it again turn the switch on and leave it on for about 3 mins. and see if it will start. If it dose I would say the pump is weak.
Sep 23, 2009 | 1999 Audi A6
2003 S-10 4.3 crew cab, is hard to start only in
although your fuel pump is running it might not have the correct pressure so what you need to do is run a fuel pressure test by connecting a pressure gage at the valve on top of the engine take the black screw cap and connect the fuel gage turn the key w/out starting the vehicle and read the pressure it hould drop only about 1 psi but no more than that if it drops more than that you need to buy a fuel pump.
Jul 04, 2009 | 1991 Chevrolet S-10
VW LT35 / hard starting when hot
have you check your fuel filter. and how hot dose the motor get when it start hard.no motor like to start when they are hot. check your fan relay. and check your coolnt ok. good luck have a nice day
Apr 18, 2009 | 2004 Volkswagen Eurovan
Insignia IS-LCDTV32 32 in. Television Logo
98 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
