Question about Zebra P330i Thermal Card Printer
Out of ribbon p330i Zebra
Im having an "out of Ribon" message but the ribon is new and its placed on the printer. What could cause this?
    Champion:
  • Zebra Expert
  • 285 Answers
Possible need to recalibrate the sensors, go to driver, and send the command !SA.
Posted on Nov 13, 2010
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
330i
please check the part number of the ribbon. seems the shipp from ribbon is faulty, try other ribbon.
May 20, 2013 | Zebra P330i Thermal Card Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
Printer doesn't recognise the color ribbon and print only in mono.
Try !SA command to calibrate ribon and printer, send command from the driver
Oct 07, 2010 | Zebra P330i Thermal Card Printer
Error in position of the output for ZM400
this is usually caused by a pressure imbalance across the printhead. Check the printhead pressure adjust dials located on top of the printhead. You might find that the left side has more down pressure than the right side causing the ribbon to move to the right.
Hope that helps !
Apr 09, 2010 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Have X3 Zebra 140Xilll printers. These printers will stop printing with a message "Error condition Paper out". But the paper is loaded. Everything seems fine. What can I do? Thanks Steve Rolland
Check and clean the sensors, also the reflective surface. Make sure there are no lables stuck to the reflective surface. Use Isopropyl Alcohol to clean.
Jan 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Card cutting ribbon on Zebra P330i
On the front of the head. 4 screws are there.
Near the head where the ribbon contacts the card.
Loosen the top 2. Let the metal guard slide down a bit. Tighten the screws. Try a card.
Keep adjusting the guard until you tune it right.
Sketchlab.com
May 13, 2009 | Zebra P330i Thermal Card Printer
Zebra P330i Thermal Card Printer Logo
463 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
