Question about Brother MFC-8460N All-In-One Printer
SCREEN SAYS TONER ERROR.. WE HAVE REPLACED TONER AND DRUM UNIT AND IT STILL SAYS TONER ERROR...
  • 12,061 Answers
Http://www.scribd.com/doc/18198278/BROTHER-MFC8460n-Series-Service-Manual
above is a service manual, inside this manual are all troubleshooting and repair procedures, look in there for your Fix..
Posted on May 07, 2010
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Oki c5550 mfp
i have the same problem with my magenta drum unit on my oki c5550 the screen says missing M drum unit and the other errors i am getting are incompatible toner C,Y,K. how do i fix these
Aug 08, 2013 | Office Equipment & Supplies
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Solusi code eror 4F on brother DCP-145C printer
In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
May 25, 2012 | Brother Ink for Dcp145c Lc-980
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have konica 7130 i got my error in the screen f-26-3
F26-3 at power up.
Solution:
CAUSE: The toner supply unit (p/n 26WA-3200) is bound up preventing toner from being added to the developer unit.
SOLUTION: Replace the toner supply unit.
Jun 04, 2009 | Office Equipment & Supplies
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Displayed error
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Jan 13, 2009 | Canon imageRUNNER 400S Copier
Brother MFC-8460N All-In-One Printer Logo
311 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
