Question about Maxtor Hard Drive
Hard disk power Socket
Hi my hard disk power socket snapped off when i was changing the hard drive. do you know how i can get it repaired please. as there is data on the drive that i would need.
  • 56 Answers
Depending where you live you could post it to me and I will repair if no great damage done to pcb it sits on
Posted on Mar 27, 2008
Hard Disk not found
If it fell down, you changed hard disk and still get message "Herd Disk Not Found", probably you've got a problem in your Motherboard.. Take it ro a repair technician
Hope you still have old hard disk. Check it as external disk on some other computer, maybe it's good!.
Jun 20, 2015 | Dell LATITUDE Computers & Internet
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
I have got transcend storejet 25M 320Gb external hard disk.....when i started using it i transferred some data from my PC to the hard disk and the transfer speed which it was showing was 1.2mbps which is...
You connected it to a "USB 1.1" socket in your computer, which is only 1/40 of the speed of a "USB 2.0" socket (if your computer has any such USB sockets). If you don't have any USB 2.0 ports, buy a PCI add-in card to add some ports to your computer.
Nov 01, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Maxtor Basic 500Gb hard drive - knocked and will not power up?
They do not generally distribute spare parts for these cases. You can however purchase new complete enclosures without a drive for a small price and transfer your existing drive into the new enclosure. As the actual hard drive can generally survive several G's worth of drop force even when running, it's most likely the harddrive is ok. Once in the new enclosure test the drive out, if it works, you're done. If it doesn't the drive itself is the problem, reply here by adding a comment with your country and city and I will pass along a recommendation for a professional facility.
Chris
Jun 05, 2009 | Maxtor Computers & Internet
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
If its just a case of the power socket broken..
I am able to recover this problem - Where are you located.
Depending on your location - will dictate the next steps..
Aug 06, 2008 | Computers & Internet
Adding harddrive
hi my name is wesley. you need to make sure the hard disk you put in is set to slave otherwise it clashes with your other hard disk and will not boot. you will see a jumper on the hard disk you can set to slave instructions is on the hard disk you just have to change witch two pins the jumper is on.
Jul 08, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Damaged Maxtor Cable Socket
NO. Its also probably the drive a suffer physical damage. Imagine a cd player being dropped as it is reading/writing, except you can change the disk. You will most likely have to ( or have a trained technician ) extract the drive, place it into a new enclosure, and test the drives stability. Hope this helps.
Sep 26, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
