Question about Belkin (F5D7231-4) Wireless Router
Belkin Network USB hub
My belkin network usb hub is not registering on my network and the power on light disappears soon after turning the unit on
    Guru:
  • 377 Answers
Hi dear
I've not had any issues like you described using the in-built Windows
wireless client. So my suggestions involves removing the Belkin software and
retrying with the built-in software:
1. Try and uninstall the Belkin client software
2. Check to see if the WZCSVC service is running
You can check this by issuing the following command:
a) net start
b) sc query wzcsvc
Both command should list some info about WZCSVC (Wireless Zero
Configuration) if it is running.
3. If your wireless card is installed successfully, you should see a
antenna-type icon in the system tray.
If not, you need to install the drivers for the card manually. Check
the Belkin CD for drivers.
4. If you can see your new router's SSID (wireless name) then you should be
able to see it as a non-admin as well.
5. Failing all of this, retry the Belkin client software and its
documentation for indication on non-admin issues or ways to use the above
mentioned Windows wireless client.
oke
cropp
Posted on Mar 27, 2008
Need windows 8.1 driver for SXUPTTP
It is compatible: http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20F5L009%20USB%20Hub&vendor=Belkin&Locale=1033%2C2057%2C3081%2C4105%2C16393&BreadCrumbPath=Belkin%20F5L009&LastSearchTerm=Belkin%2BF5L009&Type=Hardware&tempOsid=Windows%208.1
Try opening device manager (Windows Key + X then select device manager from the dropdown) Find your device: Look under "unknown devices" or "universal serial bus controllers", right click and select update driver software.
Nov 07, 2013 | Belkin Components F5L009 5 Port Network...
Seems like my belkin usb travel hub doesnt have enough power to run mouse and verizon pc card can this be possible, neither will stay working
The hub draws it power from the computer and cannot deliver enough power for the devices connected to the hub.
Does the Belkin hub have a power socket? If so get a power adapter for it. If this isn't available then purchase a powered USB hub to use with the computer.
Jul 29, 2009 | Belkin USB Hub
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
Not sure
Every plug and play devices are compatible with Vista.Vista have a huge range of drivers under its hood.So there is no doubt on that belkin usb 2.0 lighted travel hub is compatable with windows vista
Oct 21, 2007 | Belkin (B5U034) 4-Port USB Hub
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin (F5D7231-4) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
