Unlock thermastat of honeywell - Heating & Cooling
  • 43,501 Answers
Do not know what model t-stat you have and they are different depending on what t=stat you have...
Go here and down load the manul for you t-stat which will then tell you how you can unlock it...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on May 06, 2010
Honeywell wifi thermastat 6980??
Try using the calendar and not the cakender set up. Just kidding make sure your press save after you change your settings. Also if that doesn't help doubt it will much try contacting Honeywell either by phone or web site they are very good at assisting contractors or homeowners with questions about a honeywell product.
Nov 22, 2014 | Honeywell Heating & Cooling
Dont no how to work central heating system
Honeywell Focus Pro 5000 non programmable is the easiest heating cooling thermostat that I've seen.
Dec 23, 2011 | Heating & Cooling
How do i change the battery on my honeywell thermastat?
you have to remove front cover. Most times there are little snaps on the sides of cover to undo. Get a smallish screw driver and pry the cover off very carefully. any more questions just get back to me ken
Jan 31, 2010 | Honeywell Electronic Programmable...
Thermastat temp "fixed" and i do not remember how to adjust it up and down.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 01, 2009 | Honeywell Electronic Programmable...
The digital display is not functioning
the thermostat could be bad. It may have gone bad on its own or due to a short in the supply wiring. Sometimes mice will chew on the wiring in the wall that leads to the thermostat. But I wouls change the thermostat. They do go bad. Make sure you turn the inside unit off first in case you accidently touch wires together. This will blow the transformer inside the unit if the fuse doesn't blow first. I even scene thermostats with fuses inside. So you may want to take the thermostat apart and check for inside fuse also.
Jun 18, 2009 | Honeywell Heating & Cooling
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
