Question about Garden
Problem Engaging / Disengaging the Blades
When I disengage the blades on my LT1000 it takes about 15 seconds for the blades to stop and there is a lot of slack in the engage / disengage handle. Prior to this it has been extremely hard to engage the handle. Thanks in advance for the help.
  • 134 Answers
Two separate issues:
For free wheeling blades, it is time to replace the following items:
Brake Arm Pad Assembly # 131845X900 (Item 53 in picture)
and depending on condition:
Torsion Brake Spring(s) # 140086 (#58 in picture)
Take a look at Idler Pulley # 131494 (#36 in pictur, checking for wear. Sand and other abrasives will eventually wear the pulley down.
For engagement of handle: Lubricate all moving parts associated with the handle. Use only a dry film moly lubricant. Do NOT use WD40 as it is a penetrating oil and offers very little lubricating properties. Do not use oil as it will only attract dirt and eventually clog everything up.
The idler pulley previously described is on an articulating arm that must move freely, otherwise it will be (1) hard to engage and (2) cause slack when disengaged. In addition, this will result in premature belt failure.
FYI, although a Craftsman badge, this is an AYP (American Yard Product) tractor with a Murray Deck. Keep this in mind when ordering parts so you don't pay for "name branding".
Please let me know if I may assist further.
Best regards.
Problem Engaging / Disengaging the Blades - 1026a5b.jpg
Posted on May 07, 2010
  • Dennis Key
    Dennis Key Oct 23, 2010
    I need to now where the ends hook to. spring 58. The other spring on deck not aparts. I now where it hooks on lever. I need the other end. Thank you
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
BLADES KEEP TURNING AFTER DISENGAGING
the cable needs lubricated with wd40 so it will slide properly.
Jul 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Apr 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Garden Logo
1,055 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
