Question about Whirlpool GS6NBEXR Side by Side Refrigerator
No water at icemaker Whirlpool #gd5rhaxnq00
Water at glass filler but no water to icemaker. Does the infrared sensor operate the icemaker water valve, or should I think the water valve solenoid is bad? Note: weird that when i put my meter across the disconnected terminals from the water valves I only had 53v and glassfiller works but ice maker has no water. Tage on valves says 120v
SOURCE: whirlpool ice cube maker not functioning
Comment regarding catriver Aug 18 post: Shorting L&V caused valve to work I believe, at least I think I heard it operate, but shorting T&H did not cause gear to move. So does that indicste a different problem? Still no ice. JimB
Posted on Oct 05, 2007
watugot
  • 290 Answers
SOURCE: amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Posted on Nov 11, 2007
gwshaw71
  • 83 Answers
SOURCE: Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Posted on Feb 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 18, 2009
  • 77 Answers
SOURCE: Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Posted on Jul 23, 2009
Icemaker tray is not filling with water. but water
Dual water valve solenoid not operational - or icemaker timer is failed.
Test both to verify which is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | Whirlpool Refrigerators
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | Whirlpool Refrigerators
Icemaker not working
In most cases, this will be a water valve inlet issue. check the water valves operational value. you can use a ohm or volt meter to test the terminal clips on the valve assembly. if the meter picks up resistance and the valve isn't allowing proper water flow, replace the valve Assembly asap.
May 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
There is no water to my ice maker
there are three things that can cause this #1 icemaker #2 water valve #3 door eye that reads over ice bucket in door, these are a but difficult to narrow down cause but you can do it.Move unit away from wall and remove cover from bottom, the water valve is a three part component < one supply and two output > the two front vales have electrical plugs if you reverse them and operate door water the icemaker valve will operate putting water in icemaker < door has to be closed > If it does then water valve is good < replace wires to original places> if it is ok then the next step is to fill icemaker about a third full with water and wait < if it produces ice and drops it into the bucket then it is cycling as it should,<if ice stays in icemaker and does not drop in bucket then the icemaker has failed.If you do these two steps and find no failure,<both work> replace sensor that reads bucket level,<red light on right with on and off switch and opposing side pick up,> it is a kit and is easy. If you follow these steps you will find problem and get it fixed.
Mar 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
