Question about Linksys Wireless-G WRT54G Router
Need help connecting to computer - Linksys Wireless-G WRT54G Router
  • 2,260 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on May 07, 2010
Can not find camera to fit my connection.It has like a computer connection.
NEED MORE INFO BRUCE. !! camera model you have would be a help....as it seems your trying to find a camera to fit your computer connection which doesn't make sense. so im gathering you mean a lead to connect your camera to the computer.
Anyway to add pictures of the side of the camera connecting ports, we need to establish what type of camera you have first then we will be able to help.
Apr 26, 2017 | Cameras
Help me to connect 2 dell computers with cables
The easiest method of connecting any computers is to use a router which will also provide a DHCP server component to serve up local TCPIP addresses to each connected computer.
To connect to the router you would need standard ethernet cables which are available widely and which would plug into the network port of the computer and the other end into the port on the router. You need one cable for each computer to router connection.
If you have computers with WiFi / wireless capability, then you would need a wireless router and could then connect without the need for cables.
Take a look at the Practically Networked web site which has revies of various types of routers and also provides tutorials on networking and other related subjects which would help you.
Jan 04, 2012 | Dell Dimension Computers & Internet
Jan 04, 2012 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Need to connect modem to two computers so one computer can access work vpn.
Depending on how you set up the first computer, you can have one computer connected by USB and another by ethernet (straight-through cable). If you want both computers connected by ethernet, you need a crossover ethernet cable between the Modem and a router or switch (hub). You will need a straight through ethernet cables from the router to each computer.
Then set up each computer as appropriate for the type of connection (including installing drivers for the USB as needed). For more details see: http://broadband.motorola.com/consumers/products/SB4220/downloads/SB4220_userguide.pdf .
I hope this helps.
Nov 06, 2010 | Arris SURFboard SB4220 Modem
I need assistance with the front panel cables for Intel d915gav. My computer wont turn on. I dont know where to connect the connections. & I dont know why my computer wont turn on. Please help, I need...
Follow this link to the spec sheet for the board. Make sure the wires running from the inside of the front cover are plugged into the correct pins.
http://downloadmirror.intel.com/15196/eng/D915GAV_D915GAG_TechProdSpec.pdf
Oct 17, 2010 | Intel D915GAV Motherboard
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
The internet on my computer is not working. the
Download this program.
And burn the file to CD or put it on a flash drive. Install the program on the broken computer and run a FULL SCAN. This program searches for viruses and other malware that can often cause internet connectivity to fail.
Jul 07, 2009 | Toshiba Satellite Pro L300 Notebook
Download Lg kg 300 mobile driver to run internet through mobile
i have lg kg 300 and want to connect internet on computer through my mobileso i need it's driver can u help me?
Aug 13, 2008 | GPS
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Linksys Wireless-G WRT54G Router Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
