Question about Troy Bilt Tb70ss Gas Trimmer
I have a TROY-BILT String Trimmer model TB70SS and I cannot get it restrung when the string runs out. Do you have a manual that shows how to load the string for this model?
  • 134 Answers
Click Here For Your Manual.
If it takes you back to your model number & serial number, simply enter your model number and any random number for the serial. You will be able to access the manuals from there.
I hope this helps.
Posted on May 06, 2010
How do i adjust the magneto gap on a Troy-Bilt TB70ss string trimmer.
That is it. It is about that way for anything in the area of the clutch and flywheel. It is a pita but the nature of string trimmer in general.
Oct 22, 2014 | Troy-Bilt Gas String Trimmer TB70SS
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
I need an owners manual for a tb525es string trimmer
Go to troy bilt web site,here is the link to the manual page:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
If you can't find the serial number, just make up a number and it will still search and locate the manual just by the model number
Jul 19, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Too Much String from my Troy Bilt
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Jul 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
How do i install more string? Lost manual
I have the same trimmer and I fixed the problem for good by getting a shakespear line trimmer head to replace the original faulty design,it also has 4 line rather than 2 so it cuts better. It costs about $15.00
see link
http://www.lowes.com/lowes/lkn?action=productDetail&productId=120473-42694-14548&lpage=none&cm_mmc=search_yssp-_-Unassigned-_-060209-_-Shakespeare%20Universal%20Fixed%20Line%20Trimmer%20Head
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt Tb70ss Gas Trimmer Logo
723 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
