I want to replace the hard drive. I have the new hard drive but I am unsure how to procede
The 13 Easy Steps to Installing a Primary Hard Drive Compiled By Our Editors Believe it or not, all it takes is less than a half-an-hour and a Phillips screwdriver to install your primary IDE hard drive into your desktop PC. Simply follow this illustrated 13-step guide and it’s mission accomplished! Please make sure you consult your user manual and other manufacturer-provided documentation while you complete the installation - you will need to refer to instructions at certain points in the operation.
I want to replace the - image1.jpg 1. The first step is obvious! Power down your PC! And for safety measures make sure you have unplugged all your power cords.
image2.jpg 2. Next locate all the screws and/or clamps that hold the computer case and/or panels together.. image3.jpg 3. Now it's time to gain access to the interior of the computer case. Simply remove the case or the panels that hold it together.
I want to replace the - image4.jpg image4.jpg 4. If your PC happens to have a removable hard drive bracket, now is the time to remove it! It’s specially designed to be removed without hassles, and its absence will make this simple installation project even easier.
I want to replace the - image5.jpg image5.jpg 5. Now it's time to leaf through the documentation that came with your hard drive, along with any included diagrams, for instructions on how to set the jumpers on the drive. If you're the type of person who hates to read the instructions, bury your impulse to neglect this crucial step. If your system has but a single drive connected to the cable, use the “Cable Select” option; this will suffice in most cases when there is only one drive. If another drive exists it will be connected to the same IDE cable, using the “Master” setting.
I want to replace the - image6.jpg image6.jpg 6. You're almost halfway done! Wasn't that easy. Now the fun begins! Slide your hard drive into the drive bay, then fasten it down. Some cases employ a system in which slide rails mount onto the drive for easy insertion and removal fI want to replace the - image7.jpgive bay.
image7.jpg 7. Remember that removable drive bay bracket that you removed in Step 4? Now it's tiI want to replace the - image8.jpgrn it to the inside of the case.
image8.jpg 8. You will find that most ATA/66 and ATA/100 IDE cables have either a blue connector or a connector labeled “System Board.” In the likely case that this applies to your PC, plug this blue connector into either the IDE0 (Primary) or IDE1 (Secondary) connector on the motherboard. The primary connector is color-coded blue, in most circumstances, to indicate that it should be used for a hard drive. Usually, you can insert the cables in but one way. However, if the cable is not keyed for one-way insertion, make sure that the red stripe on the IDE cable matI want to replace the - image9.jpg “Pin 1” on the motherboard.
image9.jpg 9. Attach your connector that is located the farthest distance on the ribbon cable to the hard drive. Usually this connector is either black or labeled “Primary.” Make sure you place the red stripe on the cable at pin 1 of the hard drive’s connector. Note: I want to replace the - image10.jpg are keyed to allow the cable to fit in only one specific way.
image10.jpg 10. Now locate a 4-pin power connector from the power supplyI want to replace the - image11.jpg attach it to the hard drive’s power connector. You're almost done!
image11.jpg 11. Next, replace your computer case or panel.
image12.jpg 12. Tighten any screws or clamps to fasten down the case or panel.
image13.jpg 13. Finally, reattach your computer’s power supplies.
Voila! You’re done. Your hard drive should now be installed and ready for operation. Now your computer BIOS must detect the hard drive the next time you power up your PC. Double-check your PC or motherboard user manual for instructions on how to detect a new hard drive. Perhaps you may need to change some of the parameters in BIOS to detect the hard drive on the controller. You must also format the drive before it can be used with the operating system. Again, consult your manufacturer-supplied documentation for additional information.
Posted on Mar 27, 2008
How to reseat then harddrive
I'm unsure of why you would need to reseat a laptop hard drive - but it's easy to do in most laptops. Usually there is a rectangular cover on the bottom of the laptop - usually only 2 screws securing it. Remove screws, Remove cover, unplug hard drive, plug hard drive back in, replace cover and screws.
Apr 28, 2014 | Dell Inspiron Computers & Internet
IL.COMRES.SIR, PLEASE TELL ME HOW TO ADD(INSTALL) THE MISSING FILES OF OPERATING SYSTEM (XP/SP2)TO RUN WINDOWS PROPERLY,WITHOUT FORMATTING CONCERN DRIVE.PLS PROVIDE THE PROPER PROCEDER. THANK YOU.
hi,
1. Some hardware malfunction also leds to show msg of missing or corrupt windows file. So, try to remove any new hardware fixed and give a restart.
or
2. Try to upgrade the XP through the XPinstallation CD. If it is not possible then Reboot the system by formating the C:\ drive.
or
3. A problem in hard disk could be the reason. Better change it.
enjoy.
Apr 26, 2011 | Computers & Internet
About a 5 days ago I bought a 250 gig hard drive for my xbox 360 and when I went to use the transfer cable I had also freshly bought to transfer from my games from my old hard drive to the new one I was...
Here is a video where someone uses the cable and DOES NOT hook it up to their pc. Try this method and see if it works.
Thanks and please vote,
Stonecon 360
Oct 23, 2010 | Microsoft Xbox 360 Console
Hi there, i have a wd elements 1.5tb i lost my power adapter,is it possible to get one.and what will be the price,,?
Although it is possible, it's is more likely someone will sell you the wrong adapter. There are so many drives on the market and almost no standards. You're safer bet would be to take the drive to a local PC shop and ask the technicians there to move the hard drive in the chassis you have to a new chassis which will come with it's own power supply, this is usually a safer way to procede.
Chris
Sep 20, 2010 | Western Digital Elements powered by WD 320...
My xobx freezes in the startup screen when the hard drive is in place, if the hard drive is not in place the xbox starts normally. what is the problem?
There is probably something wrong with your hard drive or connection, as far as I know, the hard drive itself is not serviceable, (though I would love to be proven wrong if I am). If you can, try to get your hands on another hard drive, maybe borrow one from a friend, and try it on your console. If it works then your hard drive is toast, if not then you have a problem with the connection to you console. I don't have a repair proceder for the console connection problem as I have not yet experianced that particular issue and was unable to find someone who has, try calling 1.800.4my.xbox if a replacement hard drive does not work.
Good luck.
Mar 31, 2010 | Microsoft Xbox 360 Console
Computer doesn't recongize the external hard drive anymore; only comes up as a USB and want to install software which it can't access.
If the drive only shows up as a USB device then one of three things is wrong:
1. Your computer is suffering from a driver issue, to test this simply plug the drive into a different computer, if it works fine there report back and I will give you a hand figuring out why it doesn't work on yours. If it doesn't proceed to step two.
2. The enclosure may be faulty. Take the drive enclosure to your local PC shop, have them extract the drive from the enclosure and place it in a new enclosure to test it. If it work buy the enclosure and report back. If it doesn't, procede to step three.
3. If step 1 + 2 both failed, the hard drive itself is damage and you will need the help of a pro to recover any data on it, report back with your location(Country, City, State) and I will be happy to pass along a few recommendations.
Hope this helps FixYa,
Chris
Sep 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Where is the location of hard drive on the HP pavillion dv1000? I want to remove it to restore data.
if you turn the computer upside down there will be a plastic entry point that is a bit larger than a cigarette packet. If you are unsure your best option would be to take it to a computer store and buy a laptop hard drive cover that converts your laptop hard drive to usb. "usb2.0 hdd External Box" about $20 remove and insert hard drive to new case about $10
Now you can access your laptop hard drive easily and cheaply from any computer and when finished you can put it back into your laptop
Jul 11, 2009 | Computers & Internet
Have A HP 735P made recovery disks when computer was new the 1st time booted it up. Installed new hard drive. When I attempt to use the recovery disks I made from this computer I get a messege ''Recovery...
The most likely cause of this, is that the new hard drive is not the same as the orginal. Restore media is setup to install only on OEM. Orginal Equipement. If the new hard drive is larger or smaller then the orginal it will not properly load.
The easiest solution to this is if the new hard drive is larger, use a disk setup utility and create a partition the same size as the old drive.
If your drive was retail the software to do this will have been in the box. If you purchased an oem drive you can download the drive setup tools from the manufacturers site.
The drive setup utility is easy to use. Boot to it and choose setup drive. When selected it then procedes to the screen where you will need to set the size of the partition. 1024MB is 1 GB. This will help you detemine the size of the partition you need to set.
Good luck
Apr 02, 2009 | HP Pavilion 735n PC Desktop
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
