Question about Sony DVP-NS575P DVD Player
How many wires go from DVD to TV and what colors are they?
How many wires go from the DVD to the TV and what colors are they? Where do you insert them in the TV? There is a red wire, white wire, yellow wire, is that correct?
Where do you insert them in the DVD player?
And finally, does the TV have to be on a certain channel to view the DVD?
  • Sony Master
  • 736 Answers
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
Posted on May 06, 2010
The television does not play DVD when hooked up to player and both are turned on
Yes you need to set the input to the proper source be it RCA ,video ,hdmi etc.
Jan 01, 2017 | Televison & Video
How to hook up wires from dvd to tv, what is the order
Your tv and DVDs have color coded wires white,yellow and red..just mscth them..most have words like video or audio out and in...would be out to TV on the DVD in on the TV pretty much self explaining..good luck
Oct 05, 2014 | Sungale DVD-2026 DVD Player
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
I get the audio but video does not come on
hi.... is your player works on RCA connector? if so the audio jacks colored red and white should be inserted to your TV RCA port colored red and white too..the video jacks is yellow try re insert it to your TV RCA port colored yellow....weak video responses sometimes cause by delayed contact...hope it can help...don't forget to rate and vote...good day..
Feb 15, 2011 | Cyberhome CH-DVD 300 DVD Player
I'M TRYING TO CONNECT MY DVD PLAYER [GE 1101P] TO MY PHILLIPS HDTV. WHICH CORDS GO WHERE?
there should be 3 colored cords,if that's the way you are trying to hook it up.There is that or HDMI.For colored cords,insert the color into the matching color on the OUTPUT labeled portion of the DVD player.Take the other 3 ends and insert them into the INPUT labeled part of the TV.To access it on the TV,you will need to press the input or input select button (whatever it is labeled) on the TV remote,and select input 1 or input 2,depending on which on it is connected to on the TV.Just about all TV's these days have at least 2 inputs for an external source.Your TV remote button may even be labeled source select.You should be all set from there. Good luck!
Jul 28, 2010 | GE 1101P DVD Player
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
I have an 8500 dvd player and dont know how to connect it to tv for blackback. the tv has place for 3 color cords, but i dont know where to plug the other ends into the dvd player as it is not color coded
hey.what you need to do is
#put the tv on input (AV or LINE)
#one by one insert the cables.
#take the yellow one first insert it in the socket 's
if you have picture take the next one
that will be red and than white.
email me for more info
ruanelectronics@gmail.com
May 11, 2009 | Televison & Video
Plug into Tv?
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Dec 22, 2008 | Mintek MDP-1760 Portable DVD Player
I NEED HELP IN STOLLING MY NEW DVD PLAYER
good day,
just make sure that the colors are matched with the jock and the socket in your dvd player and your tv. just make sure that you unplug first your dvd player and tv while attaching the wires to avoid accidents.
just follow the color coding of the wires and cables and you wont go wrong. just plug in the your tv and dvd player to the electric socket and in no time you will be watching your favorite movie.
for the player, just press the open(eject) button to insert your dvd and normally it will automatically play. just hit rewind (<<) for playback and forward (>>) to skip some scenes. use the |<< button to go back to a previous section and the >>| to skip to the nest section. use the || to pause and the button with the square symbol to stop.
i hope this would help.
Oct 09, 2008 | Televison & Video
Sony DVP-NS575P DVD Player Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
