Question about GE WJSR2070B Top Load Washer
The water level shut off on my washer has all raised. The small load is about the middle now. the large load is near the top and the jumbo load floods. What do I do?
  • 1,543 Answers
Pump out water. Remove front panel by pushing in retaining clips (2) at the very top seam, where the front panel meets the washer top. Pull thin "clear" hose off left front side of outer tub. Clean the gunk out of the thin hose. Re-assemble. To prevent this from re-occuring, use a washer cleaner, such as Affresh, Waher Magic, or Whirlaway hot tub cleaner every 3 or 4 months.
Posted on May 06, 2010
The whirlpool washer overflowed and flooded the apartment
Need new pressureswitch or the pressure switch tube is not connected to tub or pressure switch itself!!! where it connects to tub at airdome might be plugged with dirt,soap ect!!!
Mar 15, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Apr 17, 2011 | Washing Machines
It does fill to capacity on the rinse cycle only on large or super levels.
Jan 06, 2011 | GE WBSR3140DW Top Load Washer
Overflow
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Water will not shut off.
1st: check to see if the hose that the water comes out when it drains is higher than the water level in the washer.
2nd: It could be the plastic line that is inside of the washer that determines the water level.
Check the hose at the back to see if it's higher first.
Let me know
Dec 13, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Wrong water level
sounds like a water level issue, it located behind the console2.gif . before replacing switch check the clear plastic tubing going to it for any cracks or holes, and make sure its attached to the rear of tub properly. air pressure goes up that tube tripping off switch so check it first.
Mar 14, 2008 | Kenmore 23022 Top Load Washer
GE WJSR2070B Top Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
