Question about Dryers
I have malber wd 800, Washer works all right, but doesn't drain water properly. 2ndly Dryer does rotate but no heat..doesn't dry the clothes.
I have a combo washer dryer n the handle broke I need one n is a wd800machine what can do to get one
Posted on May 30, 2011
  • Dryers Master
  • 43,501 Answers
Here is a tip that will help you with that...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you have a gas dryerI have malber wd 800, Washer works all right, but - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dI have malber wd 800, Washer works all right, but - 2_bing.gifa>
If your
dryer2_bing.gif is electric2_bing.gifI have malber wd 800, Washer works all right, but - 2_bing.gifere could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
How do i know if machine is condensing the water properly
Simple. When in the Drying Cycle, does the water pump turn on and pump out a 4-8 ounces of water - about every 4-5 minutes?
To check, pull the drain hose out of the wall (drain pipe) and hold it a few inches above the drain pipe, so you will be able to see when water comes out. Typically, the pump turns on for about 30 seconds every 4-5 minutes.
It is important that the cold water is turned on, and is available all through the drying cycle, because a light spray is constantly used to cool the internal condenser.
I'm assuming the Dryer is getting hot. If not, see previous posts about the Heating Element and Working Thermostat.
I'm also assuming the little blower fan is working. It's at the very top, slightly to the back right. It should be on continuously, during drying.
Remove top (2 torx screws at rear) to observe.
May 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
The machine fills with water during drying cycle and does not fill for the wash cycle
First, did you know that this machine steam dries clothes? The first thing it does on the dry cycle is to wet the clothes which it then heats to dry with condensation. There are better answers regarding this feature on fixya. But assuming that the dry cycle is working as well as it ever does, it appears that your wash cycle is not functioning properly. I would need more info to figure out why it is not filling with water / working at all.
Mar 31, 2010 | Malber WD1000 Front Load Washer/Dryer
My Malber WD1000 over floas and does not dry = can you advise me
First off, I have found that my machine gets clothes 90% dry (or 75%). Also, when I first installed mine, I did not properly drain it. The drain hose you notice comes out the bottom of the machine, goes up to the top and then goes back down again. I had to take the hose from there back up again to create a trap that held the water so it did not flow back into the machine. (I figured this out by disconnecting the hose entirely and letting the water run onto the ground.
Hope this helps.
Feb 11, 2010 | Malber WD1000 Front Load Washer/Dryer
Turn it on...no water?
Well it turns out that the pipes were not properly connected...however, I think the machine is very confusing anyway. This is my understanding of the Malber WD 1000...at this point in time. I've only used it once. The first dial (on the left) has to do with how fast you want to spin the clothes...I set it at 600 and that seemed to be fine for perm press. The second dial has to do with the temperature...I am still confused...it is the temp of the wash or dry? Its just darn right confusing. The third dial has to do with starting the wash. I put it on 3 for perm press. Now I wonder, if I turn it to 5, delicates, will it still go straight into dry mode? As a woman, I have a lot of things I dont like to dry, so if anyone figures this out before I do, please tell.
Aug 28, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
MALBER WD 800
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 03, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Jun 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
100 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
