Question about Electrical Supplies
Can't Find Correct Pull Chain Switch I have a new bathroom wall sconce that has a two lights - a regular bulb and an LED night light. The pull chain switch for it broke and no one at Lowes or Home Depot has seen anything like it. It looks like a standard pull chain 2 wire on/off, but it only has a momentary ''off''. The pull sequence is: 1. Main bulb on, LED off 2. Main bulb off, LED on 3. Main bulb on, LED on 4. both off All the switch does is momentary break the circuit. I cracked open the broken one and you can see that it's normal position is on, and pulling the chain only temporarily interrupts the circuit, then it goes back to on. I replaced it with a standard on/off switch, but you have to click it twice for each sequence, eight times for a full cycle. None of the ''experts'' at the home centers know what this is. What are these switches called, and where can I get one?
  • 843 Answers
It's called a "momentary switch, normally closed". This is sometimes abbreviated Mom Switch, NC. But I have never seen one with a pull chain before. Maybe you can find one with a toggle that you can attach a chain to.
Good luck.
Posted on May 10, 2010
  • Al Kupchella
    Al Kupchella May 10, 2010
    Maybe there is a manufacturer name on the switch that would help you in your search.
Minka aire wall control
Check to make sure the light wire is connected on the receiver. Also, If it is an add-on remote & you have a pull chain attached to the light, pull the pull chain for the light, Then try the remote. Otherwise, you probably need a new receiver.
Mar 01, 2014 | Dryers
Can't turn off fan when light is on
Not sure, but if its a new installation, I would say that the wiring has been done incorrectly. Ceiling fans with lights should be able to work independently. both on / off or 1 on, the other off.
Feb 22, 2014 | Televison & Video
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
I thought I put the wires from the old switch to the new switch correctly but now the fan does not work. The lights come on but no fan.
The pull chain for fan and the pull chain for lights are wired separately.
If you are talking about a wall switch, add a comment with clear description of old switch and new switch, screw colors on each switch, and color of each wire for possible help.
Open following link possible illustration of your pull-chain fan switch.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#fan-switch
Jul 27, 2011 | Westinghouse Electric Westinghouse...
Old fan switch has 4 wires, new one has 3. A Ceiling fan light switch is for the fan, not the light, correct?
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202191016&langId=-1&catalogId=10053&PID=500871&cm_mmc=CJ-_-500871-_-10368321&cpncode=00-29062147-2&AID=10368321&cj=true&srccode=cii_9324560&locStoreNum=577
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
2) Ceiling fan pull chain switch is for the fan only.
Jul 18, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I have a 3 way fan light switch but wires don't match the colors on my hamton bay fan what wires go where i have a black wire and a brown wire and a grey wire on the switch in the hamton bay i bought...
It takes 2 testers.
699b7e0.jpg regular tester
Continuity tester has battery and light bulb.
Use regular tester to find Hot wire that feeds old-switch.
Remove old-switch from fan
Strip back wires
Separate wires so they can be tested.
Turn on power.
Test each wire to bare copper wire -or- to green wire -or- to metal part of fan
One of the fan wires will light up tester.
This is the Hot wire.
Mark Hot wire.
Mark which color wire on old-switch went to the hot wire.
Use continuity tester on old-switch.
You know which wire is hot-on-old-switch
Pull chain and test hot-on-old-switch to both of the other wires.
When tester lights up, mark this wire.
Pull chain again and test hot-on-old-switch to both of the other wires.
At some point when you pull the chain, the tester will light up both the other wires.
This is the high speed.
Use continuity tester on new-switch.
Repeat the test for old-switch.
Identify which wire will be the Hot wire by process of elimination.
Mark this wire.
Identify high-speed wire.
Pull chain again, and tester lights up on medium speed.
Pull chain again, and tester lights up on low speed
Identify these wires and match pattern to the old-switch
If you need more help, add a comment, and I will answer
Oct 29, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Need wiring diagram live cable from switch to pull switch then to
If I am understanding you correctly .,. then like this ..
Please Vote !!
Jan 12, 2010 | Solar 2-wire Pull Chain Light Switch For...
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
Electrical Supplies Logo
146 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
