Question about Cell Phones
I can not get my 2xxplantronics bluetooth to pair with my samsung mantra phone
  • 713 Answers
Hi,here is a detailed solution on how to pair your plantronic headset with your samsung phone;
STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
STEP 3 At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
To put your phone in the pairing mode,you have to put on the bluetooth of the phone which is found under the connectivity settings in the menu.
Your plantronics headset and your phone are matched up and you are good to go.
Thanks and take care
Posted on May 06, 2010
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Can I use a plantroics explorer 210 with this nokia?
You headset should work with the phone. Try following these steps.
1 Turn on the Bluetooth feature on your phone. For most phones, select Settings/Tools > Connections > Bluetooth > On. See your phone's user guide for more information.
2 Turn the headset on. Turn on your headset by sliding the power switch forward. Wait until the indicator light ?ashes blue and red. If you don't see the red/blue ?ash,turn the headset off, wait, then turn it on again. Wait until you see the red/blue ?ash.
3 Use the commands on your phone to locate your headset. For most phones, select Settings/Tools > Connections > Bluetooth > Search > 2XXPlantronics. See your phone's user guide for more information.
4 When prompted for the passkey, enter 0000. Pairing is successful when the indicator on your headset ?ashes blue. Your headset is now connected and ready to use
Jan 14, 2011 | Nokia 6060 Cellular Phone
My phone does not find the 2XXPlantronics device. It worked fine until this week and now where 2XXPlantronics was under devices it says unknown device. Is this because this model has been discontinued?
Your phone, most probably, lost the pairing data for your headset. Delete that 'unknown device' on your phone's paired devices list. Then, turn your headset on and put it in pairing mode, by pressing and holding the call button untill the indicator light flashes in red and blue. It will stay in pairing mode for a couple of minutes. Whilst in that mode, make your phone search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You see, the pairing process between any two bluetooth enabled devices should be perfomed just once. All subsequent connections should be achieved by bringing them with each other's reach (with their bluetooth radios turned on, of course). At most, a simple press on the call button should do the job.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards,
Carlos
Nov 23, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
Bluetooth > On. See your phone’s user guide for more information.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I moved from a Blackberry world edition to a Blackberry Tour and now my plantronics explorer 210 bluetooth headset will not pair with the Tour. The Tour does not pick up the headset or my car speaker when...
I was having this exact problem and as soon as I did this it connected. I only had to do up to step 3. I have the same phone and the same headset.
How to Pair Your Headset if it Has Been Previously Paired
With Another Device
1 Turn the headset off.
Slide the power switch off, then wait until the indicator turns red
and then turns off.
Slide the power switch on. After the headset is powered on, press
and hold the call control button until the indicator light continues to
flash red and blue.
> Search > 2XXPlantronics. See your phone’s user guide for
more information.
Pairing is successful when the indicator on your headset flashes
Apr 13, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Phone will not find other phones on bluetooth
I'm sorry buddy because there is no way for your phhone to pair up with other BT capable phones because eventhough the phone has bluetooth, it is only capable of pairing with a bluetooth carkit & bluetooth headset.
The SGH-A177 does not have a File transfer profile under the bluetooth profiles that ur phone is supporting.
U need to have another higher model but call Samsung first to inquire if the other Samsung phone you want to buy has a file transfer profile.
Dec 16, 2009 | Samsung A177 Cell Phone
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
