Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere will not start.
John Deere L118 will not start. I believe it is a fuel problem as I can get it started by priming the carb and will continue to run as long as I dribble gas down the carb. After new fuel filter, air filter, spark plugs and blowing air through the fuel line all the way to the carb I cannot get gas to come through into sight through the carb when trying to start? Any suggestions? Thank you.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
  • 2,100 Answers
Did the tractor sit all winter? It sounds like the slow speed jet is plugged. You have to get it out of there and get it clean, now sometimes just spraying carb cleaner in there will do it, but, some of that stuff will turn into a rock! And nothing will get it out. The holes are tiny, I tried to drill one out once to clean it up, I had a .005 drill bit and it was too big!! You need to get apiece of wire in there, dig it out, and blow through it to make sure it is clear. I can't tell you what jet it is, without looking at my tractor, but you might need to do both, some carbs don't have the jets, just needle valves, but they plug up too. Count the number of turns it takes to get it out, and put it back the same number. Check it out, hope this helps.
Posted on May 07, 2010
Testimonial: "thanks, I was thinking it would be in there somewhere and you confirmed it. thank you your advice was very helpful."
John deere L118 engine just stopped while mowing like it ran out of gas or electrical shutoff, started back once and ran for a few seconds and died again. it just had a tuneup last month, I also put o
WATER IN GAS CLOGGED CARB REBUILD IT IF WATER IN GAS DRAIN IT OUT DRIAN CARB BOWL MAKE SURE NO WATER IN IT TRY TO START IT IF DOES SAME CHECK COIL SEE IF IT IS SPARKING WHEN IT SHUTS DOWN IF NOT REPLACE COIL 60.00 THEN CHECK FUEL PUMP GOOD PRESSURE 3TO 5 LBS CHECK ALL THIS AND LET ME NO WHAT HAPPEN WILL GO FROM THERE TO CHECK MORE THE REDNECK
Sep 01, 2014 | Garden
Gardenline petrol mower model 8846 wont start
I have a John deere L118 with a 42" and snowblower that wont start without a direct prime in the carb then runs fine. I adjusted the valves from another post (that did work for a small engine i had) but no change this time. I pulled the carb and found it clean except the o ring above the solinoid at the botton of the bowl had expanded and was not sealing the gas the way it should. Put a new one on and cleaned and air blasted just in case. Re assembled and it would not start. I turned it over and found the gas flow was as weak as a old old guy with a prostate problem. I decided to install a primer bulb just after the gas filter and it starts up every time. if it uses a gas pump to hold the prime and it does not have the engine crankcase pressure on start up to squirt extra pressure thus gas into the carb when cold, this will tax your battery and starter before it starts. I installed a Honda car battery by cutting the housing slightly. because when it snows in ontario Canada, and its cold, You want that puppy to bark!
Jan 08, 2014 | Garden
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
Won't stay running after prime runs out
starving for fuel. first check for bad/old gas, then restrictions in the fuel delivery including fuel line, filter, or buildup of debris in tank or any sharp bends or 90deg. fittings. then pull the float bowl and make sure the float is regulating fuel fuel into the bowl, but most likely your main jet is plugged. use a fine piece of wire like guitar string to runthru the jet located at the lowest part of the carb that hangs down into the float bowl. the jet will be on the side or bottom of this lower piece. put bowl back on, get gas to the carb and recheck starting problem. good luck. R
Aug 27, 2012 | John Deere Garden
My john deere l118 would not start only a clicking sound, so I replaced the battery but its still doing the same thing. any ideas?
use jumper cables and bypass the battery cables they do go bad check the safety switches as well
Apr 15, 2012 | John Deere Garden
I have a John Deere L118 Limited Edition (w/ 20 HP B&S engine), which I purchased about 8 years ago. It ran well with few problems up to late this summer. I believe the problem started when I...
The gas cap has a small hole in the middle that needs to be unplugged every year! Just take a paper clip and stick it in and move ot around. It allows the tank to breath. Let me know if this works at mmacis@msn.com.
Nov 21, 2010 | John Deere Garden
My john deere 245 lawn tractor will not start only backfires out the muffler.
There are 2 likely problems.
First spray a prime in the carb and see if the motor runs on a prime. If it does then you need to remove your carb and clean- there is likely water in your fuel.
Second- check for a sheared flywheel key.
Dec 28, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
2,247 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
