Question about Sony Playstation 3 (PS3) Console
My ps3 hard drive stopped working because it was corrupted so we was told by one of you guys to put it in another system and reformat, we did this a returned it to the original system and now it says that we need to get software 3.30 or higher in order for it to work, what do i do from here?
  • sallybratton May 06, 2010
    So we cant play anything on the system period until this update comes out? that doesnt sound rite
    Thankyou very very very much
  • 781 Answers
It looks like you need to do a firmware/software update
see here for info on the update needed
Posted on May 06, 2010
  • 1,284 Answers
Hi, i think you need to read this blog to get a better understanding of what i mean..
http://blog.us.playstation.com/2010/04/21/ps3-3-30-system-software-update/
http://www.ps3blog.net/2010/04/21/ps3-3-30-system-software-update/
Take care
  • Shehu Pro
    Shehu Pro May 06, 2010
    Yes sir!, all you need to do is to be patient. It will probably be out before the end of this month...
    Take care
My Ps3 Hard disk system is corrupted i need suggestions
Your hard drive may have failed, if you can boot the system, attemtp to reformat the system, otherwise you will need to purchase a replacement Hard drive for your system.
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Hard disk corruption. says press x to resore but wont load past 18%
Try this:
turn on ps3 press x to restore on 0 % quickly pull out hdd. then wait may take up to an hour a message will come up to formate hdd. put hdd back in and press yes to format this process worked with in seconds for me but can take longer. it does work but you will lose all saved stuff but online stats will still be on the system. good luck hope it works for u to.
________________________________________________________
or this:
New fix (possibly), and it doesn't take a laptop or a friend's PS3 to do.
Simply remove the hard drive from your PS3, and turn on the console. It should display a screen saying the hard drive will need to be reformatted. Then, plug the hard drive back into your PS3, and allow it to reformat. Your save game data will be erased, but you should be able to use your PS3 again.
_________________________________________________________
whoever has a problem withe their ps3 needing to be reformatted just take out your hdd when the restore comes up, then press x, it will take a will before the ps3 tells u to insert a hdd to be formatted (took me 12 minutes)
good luck
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
The hard disks file system is corrupted.
If you can still access the PS3 menu, then reformat your hard drive by going to:
Settings > System Settings > Format Utility > Format Hard Disk
If you cannot, then you can try:
1) Remove the Hard drive, connect it to a PC and reformat it.
2) Download the latest PS3 operating system from the Playstation website and store it on a USB drive. Then insert the USB drive into the PS3 and start the PS3, and then install the operating system from the USB.
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 continously restoring hard drive
there are bad sectors on the hard drive which is why it keeps restoring cause it can never read all the info properly.
My suggestion would be to get a new 80 gig hard drive, put it in there, reformat it and youll have a great working system.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
40G PS3 system corrupted
Hello. If the hard drive will not reformat inside the PS3 when you press X, then you will need to remove it and reformat it on a PC using an external device or replace the hard drive. Thanks.
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
I have looked around for you and the only solution that seems to work for a lot of people is to take the hard drive out, put it into another ps3 (friends etc..) and reformat it, then replace it into your system and it will ask you to reformat it again then all should be well. Other to that you can always buy a new hard drive and replace the old one.
I hope this helps
Dec 24, 2008 | Sony Playstation 3 40GB System Console
"the hard disk's file system is corrupted and will be restored"
           Ok, it appears that your hard drive in your PS3 is corrupt and needs to be reformatted. You can get an external hard drive enclosure and do it yourself. You would have to take the hard drive out of your PS3 and put it in the external hard drive enclosure and plug that into a computer with the supplied USB cable and format it. From what I'm reading out there, the external hard drive enclosure has to be for SATA 2.5" hard drive.             You could probably replace the hard drive with a larger one just as easy if you wanted to. If you don't feel comfortable with any of this, then its probably repair shop time. I hope this helps.moreover,,Use your recovery disc to reinstall your operating system. This should clean up your hard drive and restore any missing or corrupt files.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
