Question about Homelite Garden
How to rewind string on a homelite st175g trimmer
2 Suggested Answers
  • 27 Answers
SOURCE: how to replace string in a homelite trimmer
have the same weedeater, see utube vids too hard to explain with words
Posted on Jun 10, 2009
I have a ST-385BC that will not feed the string, how do I rewind?
Go to smalleng.com or you tube you will be surprised whats out there. Good Luck....
Apr 18, 2011 | Homelite Mighty Lite Lawn Trimmer
Manual home lite st175g
I could not find your specific model but I do have this one:
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
Nov 09, 2010 | Homelite Garden
Pull start
Good chances is that the cord either got pulled to far out or the spring let go inside the cover that controls the rewind. It's not a big job...just remember how you took it apart www.nnyparts.com
Jun 01, 2010 | Homelite Mighty Lite Lawn Trimmer
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
String stuck out and cant get cover off to rewind it.
disconnect throttle cable from carb lever. remove about 5 black star bit screws from front of housing. engine will slip back out. swing to side to get to the spool, or remove the two kill switch blades from their posts to totally remove engine out of way.
Jun 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
354 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
