Question about Microsoft Windows XP Professional
Multiboot computer, Second OS unavailable after reinstall of XP
I reinstalled Windows XP on a computer with two different operating systems. It seems that the master boot record was wiped of any record of the second operating system. Is there some way to restore the second operating system so that I can boot to it, besides reinstalling it again? This is the way in which I have solved this problem in the past. I cannot alter the boot.ini file to recognize the second partition as it is now. How can I fix this without reinstalled OS #2?
  • iahawki81 May 07, 2010
    I appreciate the suggestion, however it did not solve my problem. I attempted to run the bootcfg /rebuild command to get my pc to recognize the second OS, Server 2003, two different times, once with no options and second time with the /Fastdetect option set. Any other suggestions?
  • 264 Answers
The problem can be solved easily if the second operating system was a windows based operating system.If it was a windows operating ,the following steps will give you a solution
In order to regain the boot path for old operating system
follow the following steps
1.Insert the Microsoft windows xp installation cd into a cd drive and boot the computer from the cd
2.In the microsoft setup page select the option of R ie recovery console
3.Select the operating system in the recovery console by selecting the operating system NO eg 1 and type the administrator password
4.Type the following command in command prompt
bootcfg /rebuild it will search for existing operating system in the hard disk and prompt you to add select yes .
5.once you completed type exit
Posted on May 07, 2010
How to reinstall windows xp thinkpad x41
How to Reload Windows XP Without Removing Files Deleting system files, modifying the registry and installing incompatible drivers to Windows XP can damage the integrity of the operating system, rendering it inoperable. Virus infections are often responsible for making the aforementioned changes to a system, but employees who have administrative access to the workstation can make deleterious modifications to the OS as well. Reinstalling Windows XP can repair the OS, but if work-related files are stored to the system partition, all of the data will be erased during the installation process. To reload Windows XP without losing files, you can perform an in-place upgrade, also known as a repair installation.
Step 1
Insert the Windows XP CD into the optical drive and then press "Ctrl-Alt-Del" to restart the computer. Step 2Press any key when prompted to load the contents of the disc. Press "Enter" on the Welcome to Setup screen.
Step 3 Read the license agreement, pressing "PgDn" to scroll down the page. Press "F8" to agree to the terms. The CD will search for previous installations of Windows XP. Step 4
Press "R" to repair the selected operating system. The disc will begin reinstalling the operating system to the hard drive without affecting personal files. Follow the on-screen prompts to complete the repair installation. Step 5
Log in to Windows XP and sign on to the Internet when installation completes. Click "Start," "All Programs" and then "Windows Update." Step 6
Click "Scan for Updates" to search for applicable service packs and hotfixes to reinstall to the OS. Step 7
Click "Install Now" to bring the in-place upgrade up-to-date.
Things Needed
  • Windows XP CD
Tip
  • Make sure you have your Windows XP product key (found on the CD cover or on the computer case) available prior to reinstallation.
Warnings
  • If possible, back up your files previous to the installation in case something goes awry during the process.
  • You will need to reinstall all non-native programs and removable devices after performing an in-place upgrade.
Apr 27, 2014 | Lenovo ThinkPad X41 Tablet PC
Tip
How to remove Multiboot Option in Windows
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
on Jan 08, 2010 | Computers & Internet
I installed a windows xp proffesional and formated the hard drive. now there are two operating systems. I cant get on the internet with the new one and the computer wont allow me to go to the old system. I...
remove one os on your computer. its will never work that way.reinstall the new os that you have with the cd. once you uninstall and reinstall the operating system you must be online wired directly to your modem. or wireless if your computer has the wireless adaoter and you have a wireless network from a router of a gateway.
Jan 20, 2011 | Computers & Internet
Os reinstallation /repair
Yes try to do so, select boot from CD using OS CD, follow the instruction, after searching previous Operating System type "r" to repair the OS
Apr 11, 2010 | Microsoft Windows XP Professional
I have no video output after reformating my hard drive. but the computer goes through its boot sequence.
Reformatting your hard drive means erasing your operating system.(OS). Therefore, you have to reinstall
your operating system (Windows XP, Windows 7)
After you reinstall your OS, you must also reinstall the
software driver for sounds, and video. All software drivers
must be compatible with your OS.
Nov 07, 2009 | Iwill KK266Plus Motherboard
Just insert the cd on the drive and restart you computer.
Follow the on-screen insctruction
Jun 21, 2009 | Computers & Internet
Boot Loder Problem when working with two operating System
best practice it when installing windows and linux install windows first and then linux. GRUB or LILO boot loader is much better then windows boot loader and very easy to reinstall. Mandriva cd should have a rescure feature that will allow you to reinstall the boot loader.
Jan 15, 2009 | Computers & Internet
I accidentally removed ms office from computer. can i reinstall it with the xp disc?
ms office is not a builtin companion of xp or any windows os you should buy it as seperate, to reinstall you have get ms office installation CD
Aug 22, 2008 | Computers & Internet
Demo problem
If you have installed vista as a multiboot sytem, then you can do the below: Otherwise you have to do as tom19511 said:
Uninstall Windows Vista on a multiboot system
Applies to all editions of Windows Vista.
You cannot uninstall Windows Vista. However, you can change the code that starts the operating system (often called the master boot code), and then remove Windows Vista from your multiboot system and return to Windows XP or Windows 2000. You will need your Windows Vista installation disc for this procedure.
Before you begin, back up your programs, files, and settings. Removing Windows Vista is an advanced procedure that could result in losing information stored on your computer. For information about backing up data, search Help and Support for "back up."
1) Insert the Windows Vista installation disc.
2) Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3) Type [DVD drive letter]:\boot\bootsect.exe /nt52 ALL /force and then press ENTER.
For example, if the DVD drive letter is F, type f:\boot\ bootsect.exe /nt52 ALL /force.
4) Eject the Windows Vista installation disc.
5) Restart your computer.
Your computer will start in the previous version of Windows that you have installed.
6) Delete Windows Vista files and folders, such as the Program Files, Users, and Windows folders, manually.
Note: You can also remove Windows Vista by reformatting the partition where it is installed, but do this only if that partition is not the boot partition. Reformatting the boot partition might make your computer unable to start.
Nov 14, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
