Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave Fuse keeps blowing
We have a GE Spacesaver model JVM1660WB 003 which keeps blowing the fuse. We have checked and replaced the fuse and that doesn't seem to be the problem. Is there a relay switch somewhere that could be the problem. The lights and timer, message panel, etc all work until you try to cook something. Any ideas???
  • 3 more comments
  • Anonymous Jun 10, 2008
    GE Model# JVM1650CH01 Microwave Oven trips the circuit breaker, 1-2 secods after the microwave is turned on to cook. All other features works, i.e. vent, lights, clock.
  • Anonymous Jul 21, 2008
    I have a similar problem. GE Model# JVM1650CH01 Microwave Oven. Sometimes 1-2
    seconds after pressing "start" it just shuts off, and acts like it "reboots". I have to reset the clock time and date. Then try to cook again. Sometimes it will then cook normally. Most times it just keeps on shutting down and rebooting itself.
  • geschoss Jul 21, 2008
    Sometimes 1-2
  • selts Sep 18, 2008
    We have an 8-year old GE Profile Spacemaker jvm1660bb003 that suddenly started working intermittently. Sometimes after pressing start the light goes on, but nothing else is happening. The turntable doesn't turn on neither does the fan or the motor. We unplugged and plugged it back in and so far it seems to be working fine. Any clues on this one?
    Thanks!
  • Anonymous Mar 16, 2014
    all power workin until ya switch it on to cook then glass fuse blows
  • GE Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
Where is the fuse located on model jvm1851wd001
Posted on Jul 21, 2008
GE Spacesaver JVM1660WB turntable does not rotate?
My range works and oven lights? Does this mean that the problem is the Relay or the thermostat? The heating elements for the broiler/oven look fine and so do the connections?
Aug 16, 2013 | Amana Radarange Microwave Oven
The plastic door handle broke again. This is the second time. It is the over the stove model. Mdl #JVM1660WB 003, serial # FZ924264S I replaced it the first time. Is there an easy way to do this?
well if you replacedit b4 it should be easier to replace it again. there is not a special handle thats stronger that will not break that i know of. im not sure if you replaced the unit or the handle.write back and let me know
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
All of a sudden my JE1540WW 003 has died.
check the slo blow fuse and the high voltage capacitor and the high voltage fuse. good luck.
Jul 10, 2009 | GE JE1540 Microwave Oven
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
GE Microwave does not heat and makes loud buzzing noise.
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
Dec 10, 2008 | Whirlpool GH8155XM Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Where do I find the fuse?
yes you do and this is not reall advisable as there is high voltage components inside.thre is normally a fault with the machine if it blows a fuse.if you want to still try then make sure yoiu unplug it and short the plug on some metal to get rid of any stored charge.the main things to blow a fuse is the door switches sticking,the bulb blowing or a fault with the high voltage system which you would need a special multimeter to yest,hope this helps
Jul 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,610 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
