My tv no have colors - Televison & Video
    President:
  • 3,130 Answers
Not sure if this is your problem but a lot of electronic tuners in tv sets fine tune the input, (antenna,cable or satillite box) so you need to turn off the TV set as well as the input sourcethen turn on the input source then turn on the TV set, if that does not work than the set has a chroma(color) circuit has a problem
techman
Posted on May 08, 2010
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
SljThere is a sound like a motor
Ur tv have a colors wheel design into it.The tv colors wheel it is defective and it is worn out,it is not spinning inside it motor mount axis motor baring anymore.The tv colors wheel is it defective that where the motor noises came from.The tv colors wheel it have to be replace to solve this making motor noises problems.The tv colors wheel it is sit way back of the tv.If u don't have any mechanical skills like take many mechanical parts aparts and putting it back together again.Don't atemp to change the tv colors wheel ur self.Hire a tv tech. to change the tv colors wheel.
Sep 22, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I am thinking about buying a Samsung 72" DLP (Hlt7288wx/xaa) for $500. The seller says a tv repairman says it needs a color wheel replacement. Do you think this is something that would be difficult to...
Yes,tvs with a colors wheels design into it are more prone to brake down and more quickly than tvs without colors wheels design into it.The colors wheel in the tv spins at 12000 RPM at every cycles to make and let the tv Light Engine shine a beam of light into a colors wheel to make and have a colors spectrums to make it to works for the tv.No projection tv with a colors wheel are not easily to be replaced have go through alot of trouble to replace a colors wheel itself.The tv colors sit way back of the tv have to take out many tv mechanical tv frames bulk heads even than can come to the tv colors wheel itself to replace it.Take ur $500 buck buy a "40 LCD tv less worry less head aches.
Aug 22, 2011 | Samsung HLT7288W 72" HDTV
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
The picture works but there is a loud roaring noise when you tourn set on
The tv have a colors wheel design into it.The tv colors wheel is dying and spinning off it motor axis.The noises u are hearing are the colors wheel is grinding and hitting it steel hall of it frame box.U have no mechanical skills don't tries to replaced the colors wheel by ur self,because the colors wheel sit way back of many mechanical parts of the tv must take out before even can come to the colors wheel itself to replaced the colors wheel itself.Hire a tv tech to do the job to change the tv colors wheel.If u have no mechanical skills to take out and putting it back of tv colors wheel itself,because u will regret it,if u do it ur self and putting in the colors wheel in the wrong way to the tv itself.
Apr 14, 2011 | Samsung HLN5065W 50" Rear Projection...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Color is terible and can fix it
This DLP tv have a colors wheel.Ur tv colors wheel is dead.When u have black & white picture,colors fade in and out.The tv make loud squiling or loud motor noises.All these problems are related to the colors wheel.Hire a tv repair Tech. for this job,because the colors wheel,require take out alots of machanical's parts out even before to get to the colors wheel to replaced it.
May 29, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
