Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
My pump is no longer working my pool water is starting to turn green, I shut down the power but I can't seem to open up the pool pump to clean the basket can you give me any suggestions?
  • 990 Answers
First get some liquid chloriene in the pool start with about four gallons. Loosten the lid ring then turn the pump on and back off after a few seconds. If your trying to get the pump housing open do the same thing with the lock ring that holds it closed.
Posted on May 07, 2010
How do I fix an Jandy ePump?
open up the power box see if still wet dry out make sure communication plug is dry then power everything down reboot and try again if it doesnt work the main board in the pump is no good
May 25, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
on Sep 17, 2013 | iRobot Mirra 530
Our pool is green, the water seems to be bypassing the filter cartridges. Trying to figure our what could be broken to get this working properly again?
You may have a broken manifold. That's the part at the bottom of the tank where the filters set down on.With the filters out and the tank empty, fill the manifold with water. The water should stay put indefinitely. I the water level drops, you need to replace the manifold because even if the crack looks small. under working pressure in will open up and allow most of the water to bypass the filters altogether.
Aug 22, 2013 | Pentair Clean Clear Plus Ccp420 Pool...
My saltwater pool turned agreenish color what do i do to fix it
If possible take a sample of the water to a pool shop. They will tell you what to add to clear water. Also filter should be cleaned as may be blocked with the green algae.
Jul 05, 2012 | Intex Automatic Salt Water System for ...
I have a Leisure bay with G2 controller, We shut the jets off for a few minutes and when we went to turn them back on neither of the pumps would start. I noticed a burning smell and turned off the two...
Sounds like wires fried or a circuit board failure. It would seem to me that once you open it up your going to be able to notice where the failure is.
May 07, 2017 | Pool & Spa
I GOT A 2 SPEED 1.5 HP WATERWAY POOL PUMP.MY WIFE CLEANED OUT THE POOL AND SHUT IT DOWN TO CLEAN OUT THE BASKET AND FILTER.WHEN SEE RESTARTED THE PUMP IT SEEMS TO HAVE LOST PRESSURE.WHEN IT IS ON HIGH ITS...
Sounds like you don't have the pump lid "0" ring seated properly under the lid, or there is dirt or leaves on the "0" ring. This has to seal perfectly or the pump will not pump much if any water.
Sep 01, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
149 people viewed this question
Top Jacuzzi Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
