Question about Sharp AQUOS LC-40C32U 32 in. LCD TV
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only that blinking light.....Help
  • Sharp Master
  • 736 Answers
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
Posted on May 06, 2010
Testimonial: "Thank you. I will let you know how it all works out."
Why won't my tv turn on?
Check Mains Cord is ok
Checked power supply board . Replaced Power supply Board
Dec 16, 2015 | Sharp AQUOS LC-70LE732U 70" 1080p LED-LCD...
How do I replace a broken circuit board on a Sharp LC-60E78UN TV?
You can either remove the power supply and check and replace caps and most likely the transformer (pop sound). Or a replacement can be found on eBay, amazon, etc... One model TV can have numerous diff power supply models from revisions and improvements. If you replace the board make sure you look match serial numbers on board to the new board. The back of the TV will come off very easy. Lay TV face down on a flat surface(making sure nothing is touching the LCD) remove screws. (Make sure cable coax slides free, some have a retainer but to remove) once the back is off the layout should be so simple, you should have no problem identifying parts.
Sep 12, 2015 | Sharp AQUOS LC-60E78UN 60" LCD TV...
My Sharp Aquos TV will not turn on...just a green ligth flashing...something to do with power...how can i fix it?
The most common issue on these is the power supply boards. Bad capacitors on these boards are the issue and there are repair kits available if yur qualified for the repair other wise you can get new boards and swap them out. This is the most common issue in the business right now. Sharp sets are a little different in ther design on the power supplies but parts can be had and repairs can be made. You will need to balance the price for the repair vs a new set. Just Google TV power supply repair kits for Sharp Aquos and you will find repair kits and information on the power supplies.
If this was helpful a vote on the thumbs up would be greatly appreciated for the free advice.
Aug 22, 2011 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
If my Sharp Aquos 37in LC-40C37U tv needs to be reset how would I do that? Not getting any power, only a green blinking light. The power supply board checked out ok.
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Apr 30, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Blinking led
Free diagrams unlikely to be available take the board's out and check for blown capacitors following good antistatic procedures and decide from there
Or find a good independent repair specialist to do the work and set your self a budget
My sharp aquos stopped working with a blinking power light £2000 was the repair quote for a new board and LCD panel for a £699 TV after they tried the capacitor replacement
Jul 01, 2017 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My Sharp Aquos LCD TV LC-40C37U will not power up. The green power lamp at the bottom right is blinking. We had a power surge last night, I even measured 180V on the power outlet. Is my TV now damaged?
Good day sir/maam, chances are, yes or no, yes, the surge do has the ability to damage your TV, but no, modern TVs are autovolt (it can work from 90v-240v) so check the manual or back panel to confirm. The most deadly part of the surge is it can hit more than 500v at a split of a second, damaging your TV's switching power supply. The TV's power supply is bad. it cannot produce the proper voltage to power your TV. thats why its on standby. Bring it to your dealer for proper advice on the status of your TV.
Oct 12, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp Aquos LC-20B6U-S TV NOW HAS NO SOUND OR PICTURE. IT APPEARS TO COME ON BUT WITH NO PICTURE OR SOUND.
This can be caused by many different things. Check power supply fuses. If ok suspect inverter board which drives screen. Check for bulging capacitors and open transformers or just find replacement cost using numbers on board. That may fixya.
May 29, 2008 | Sharp Televison & Video
Sharp AQUOS LC-40C32U 32 in. LCD TV Logo
962 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
