Frigidaire Washer How do i get to the front drain hose going to the pump on my frigidaire front load washer model # atf8000fg. Thanks
  • chris leck May 06, 2010
    Did you send a breakdown picture ? i did not get it. What about getting the big hose off to get the strainer out ? it is clogged and i can get to it to clean it.
    thanks
  • chris leck May 22, 2010
    Perfect thank you. Sorry it took me so long to reply.
    President:
  • 512 Answers
Here is a breakdown of machine, you remove back cover to get into machine, pump is at bottom. I would not take any of front off, tub will come out. Back is #28, Pump is #35. Hope this helps you.
Posted on May 06, 2010
  • Frank Meola May 07, 2010
    I sent a break down, for some reason didn't attach.
    Go to WWW.appliancepartspros.com put in brand then model. They have a break down of a atf 7000fg. Same as a 8000. Click on the pictures to the left of screen and you will see how machine is assembled. Big hose is connected to the pump, and another hose part#41 is also attached to pump.The hose just connects to pump with a squeeze clamp, easy to remove.
Dr error will not drain
Hi, your pump is either bound up with something in the chamber, or there is something in your discharge hose blocking the water from escaping.
Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Check if there is anything in the chamber that is binding the impeller. If not, remove the metal back and check that all three of the hose connections to your pump are open and have no debris/ change, etc. If there is nothing binding your pump in any of those locations, your pump motor may be failing. I would suggest calling someone out to assist you.
Aug 02, 2012 | Frigidaire ATF8000FG Front Load All-in-One...
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (ATF6000ES) Front Load Washer e20 error
You have a drain pump issue: 1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a 2 year old frigidaire front load washer.  The spin cycle starts, but only runs really slow.
all washers must drain before will go into high spin.is your's draining?the front loader type's of washers are good for getting the pumps blocked up with stuff that was in our pockets etc....too get to the pump remove the bottom front panel.the pump is the white or tan unit with two hoses to it and two wires on the right side of the washer..there are some bolts retaining the pump to the washer floor.remove and remove hose and drain into a bucket.then clean out pump.if you turn off water at house fill hose's you could put in spin at that point to test.then put all back together.if you need more advise you can email th-u fixya. God bless ,tom
Jan 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
