Question about Imperial IFS40 Deep Fryer
It does'nt kick the fire. - Imperial IFS40 Deep Fryer
  • 77 Answers
Check the thermostat for continuity. Check the millivolt output for the pilot generator. Check the high limit for continuity.
If all these are correct... the fryer will light. Make sure you turn the gas valve to the ON position after lighting the pilot.
Tom
Posted on Aug 17, 2010
Why doesn't my Pentair Minimax NT heater fire?
Does it try to fire? Do you hear the blower kick on? If it only says E-- you might have a bad control input board. For it to fire the thermostat light, and pressure switch light must be lit up. Also you must push spa or pool mode on right...
Apr 29, 2015 | Pentair Pool & Spa
Will only start with full throttle, no back firing, tried a compression test but ca\nt get a reading at all, when i take the spark plug out and kick it over ther is air coming out the cylinder but when you...
I have a few ideas to get you started but if they don't work for you please write back with more specific details about your bike. You are my eyes and ears. I don't know anything about what your bike is, its history, any maintenance or repairs that were performed or not performed. I don't know but it sounds like you are describing a 2stroke engine. If so. ho old are the "Reed valves)? How old are the spark-plugs? Have you tested the coils for operation? When the plugs fire, is the spark a bright blueish/white ark? Have you inspected the intake manifold for dry-rot and cracks or breaks? If the intake manifold is damaged or a vacuum line is broken, this will cause a hard start. Please write back with what you find and with more details and I'll do my best to help you find a solution. Good luck.
Mar 15, 2014 | kawasaki Motorcycles
New dell n5010 will nt conect to my home wirless.......... can get on pubic but nt my home one .... and if it does get on will kick off in a few mins but now can nt get on at all ?
Try changing the channel fo the router to 11, default channel interferes with cordless home phones, which broadcast 1/2 of a mile
Mar 13, 2011 | Computers & Internet
I have a 2004 ktm smc.my probem id i kicked it over, it started and after about 4 seconds it died and it sounded like bearings grinding when it died i started it back up it sounded fine thean it made the...
The grinding noise could be many things none good.
Has the bike enough oil & is it being pumped round OK (does the radiator heat up?)
If there was no grinding noise on the way home it could well have been the kick-start mechanism; as the footpeg fouled the kick-start, its mechanism didn't pivot far enough round to disengage from the ratchet. So the noise you heard was the mechanism returning but still in contact with the ratchet. This is the most likely answer.
When you adjust the decompression valve it actually depresses an engine inlet valve. You may well have adjusted it too far leaving the inlet valve slightly open as it fires, giving you back-firing in the inlet tract
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
I am available on 'Live Chat' at the moment if you need more help
Apr 16, 2010 | 2004 KTM 625 SMC
89 saturn fan does,nt kick on
cooling fan or heater fan? if its cooling fan then the coolant temp sensor is bad
Jan 06, 2010 | 1999 Saturn SL
The commpresor, trying work,but does,nt keep on, thats why does,nt get cold
Put a hard start kit on the compressor and you should be fine. Call us for parts! Hope this helps! Ella
Aug 18, 2009 | Refrigerators
Imperial IFS40 Deep Fryer Logo
103 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
