Question about JVC AV-48WP30 48" Rear Projection Television
Convergence I have red lines . Is there any way to get rid of them
  • 2,326 Answers
The only way to fix this red lines is to replace the convergence ICs.
The ICs part markings are STK392-110, located just under the CRT's mounted on heatsinks, you will see them as soon you open the back cover.
If you have basic hand soldering skills, this is something you could do yourself.
I fixed one TV today with the same failure and same model.
Let me know if you need more assistance.
Posted on Mar 27, 2008
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
How do I get rid of a red shadow in the upper left of the screen?
U can't tv have parts problems.Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the picture,have picture colors shadows or 3D pictures look like.The tv have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv convergence picture problems.The Shop,will cost u like $300-350 for parts and labors.
Oct 22, 2010 | Pioneer PRO-200 60" Rear Projection...
I can set convergence lines on red and blue lines. the
Replace both of your convergence ICs they are big black ICs will have STK392-110 on them Call Mats 1-800-628-1118 10.95 each.
Jan 09, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Need help
Check the Convergance settings....this is where you line up the lenses of the projection system to make a White line putting all the RGB on top of each other...this willl get rid of this glow.
Sep 14, 2009 | Televison & Video
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Rainbow lines in my projection tv
You have convergence problems. The convergence IC's that line up the red, green and blue crt's are bad. They will need to be replaced. Suggest a qualified tech do the work due to the complexity and alignments afterward
Dec 12, 2008 | Televison & Video
Phillips 55in widescreen hdtv
you convergance amp is is shot
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 14, 2007 | Philips 60PP9202 60" Rear Projection...
Kp57wv600
One of the convergence output IC's has stopped working and needs to be replaced. If the IC shorts out then it will draw too much current and possibly blow a fuse, and the set will shut down to protect itself. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 20, 2007 | Sony KP-51WS500 51" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
22 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
