Question about Dewalt Heavy - Duty 12" Double - Bevel Compound Miter Saw - DW716
Remove locking pin and replace with new pin
The locking pin that holds down miter saw down when nut in use
2 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: How does one replace the pin in a sliding compound
I"ve never had to replace one, but here's an exploded parts diagram that shows it has an o-ring on it. I'm guessing its a friction fit and maybe you can just knock it out with a punch or drift, or maybe twist it out with a pair of vise grips...but I don't have the saw in front of me, and can't remember if the back side of the pin is accessible.
Anyway, FWIW, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 22, 2009
Need to replace a miter saw blade on Black & Decker saw
If you don't have a manual, you can contact Dewalt, and they will get you one or help you. UNPLUG THE SAW!! , if your saw has a blade lock, engage it, if it doesn't hold the saw firmly on a scrap piece of wood. Then use the correct wrench and loosen the retaining nut. Take the nut off, remove the blade
Feb 24, 2014 | Black & Decker Saws
Cant pull out locking pin on miter saw
There is a heavy spring which is trying to hold up the saw that is working against you. Press down on the handle of the saw so that it moves down a little, now you should be able to pull out the pin.
Good luck.
Jun 13, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
How do you replace a broken locking pin on dewalt dw708 miterbox? thx
You do not have to drill anything out, if you are talking about the hold-down locking pin that keeps the blade assy locked down when not in use. I have created a tutorial for replacing the locking pin, you can find it here, http://mgfic.com/dewalt708_lockingpin.htm
Oct 14, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
HOW TO CHANGE BLADE
Do you have the wrench that came with the saw? It should be slid in the back somewhere, there is a lock on the top that you hold the motor locked with, unplug the saw, turn the nut on the blade, start the saw down and grab the guard with your thumb to hold it and then lift it up all the way to slip the blade out. You should be all set.
Jun 20, 2010 | Makita 10" Compound Miter Saw LS1040
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Craftsman Miter Saw - can't remove the blade
It is left hand thread and if the lock won't hold what you can try is put a 2x4 on the table and pull the head down against the wood and with a good socket and ratchet loosen it that way.. remember to tighten to loosen
Jul 20, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Need to change the blade on a craftsman 10'' miter saw model 137.23498, how do i do it?
First off, unplug the saw. No need to remove the guard, though you may have to loosen the cover over the lock nut to access it on some saws.
Look for an arbor lock button on the back side of the blade housing or motor, to lock the blade in place.
Hold that down and use a wrench to loosen the nut holding the blade on.
If you don't have an arbor lock, you'll have to wedge a 1x 4 or 2x4 under the blade and hold pressure on the handle to keep it from spinning while you loosen the lock nut. Once it's loose, spin it off and remove the washer and blade, replace and retighten the nut.
Should be pretty straightforward, as long as you have no power to the machine and lock the blade from turning, not too much can go wrong.
If you want to find an online manual with instructions for your saw, please try Sears online support site at www.managemyhome.com.
May 14, 2009 | Craftsman Saws
Dewalt Heavy - Duty 12"  Double - Bevel Compound Miter Saw - DW716 Logo
161 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
