Question about Kenmore Elite 45986 Front Load Washer
Billow ring and front clamp
I need to find the instructions on how to replace the rubber billow ring in the front door along with the thin clamp that holds it in the front. Also, where is the quickest and best place to order the part as Sears quoted a 9 day turnaround.
  • 5,911 Answers
The following link explains how to access and replace the door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Step 12 refers to how to reinstall the front bellow clamp (wire hoop with a spring).
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. The part number for a replacement bellow for the model you listed this question under is 8182119.
If you have questions about this repair, please post back and let me know. I hope you find this information helpful.
NOTE: The delivery time for parts depends on the postage you are willing to pay. Each site varies, so you will need to review their shipping costs. Some ship in as little as one day.
Posted on May 07, 2010
I bought a acura 96 car drives great just smokes bad uses min oil
Blue smoke often means bad rings. Expensive repair. Black smoke could mean bad valves. Also an expensive repair.
Check compression. Your mechanic can do that easily, and should not cost a lot.
Aug 08, 2016 | Acura Cars & Trucks
Video for replacing billow on a wfw94hexw
Click this link if this is what you meant: door seal
Jan 21, 2013 | Whirlpool Washing Machines
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
A HOLE IN THE RUBBER SEAL
You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --WoobieDog--
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
A wire ring came off
Hi Bert,
That ring (it has a spring on it, right?) is used to clamp the outside of the rubber boot to the outside of the frame <--- where the door closes.
All you have to do is open the door and kneel down in front of the washer. Now, with clamp in hand, work it back into the groove around the outside lip of the boot. Here's the thing you have to know... That spring? It MUST be located at the 6 o'clock position! So when you are putting this thin back, just make sure the spring is located properly.
The reason? Frankly, I don't know. But the Kenmore/Whirlpool service repair manuals say so! So that's what I do, HA!
Anyway, If you don't replace that clamp and you continue running your washer that boot will dislodge from the front panel. Know what happens then? Call Noah, cause there's gonna be a flood.
Hope this helped you! If so, would you please be kind enough to rate me? Thanks!
SG
May 23, 2009 | Kenmore HE2 Plus Front Load Washer
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
152 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
