Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 1554 engine pulsates. Seems like one
Cub Cadet 1554 engine pulsates. Seems like one cylinder is not getting fuel. I was driving it and it acted as if it was running out of gas out of nowhere. Any ideas?
  • 40 Answers
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
  • 109 Answers
SOURCE: Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Posted on Apr 22, 2009
  • 110 Answers
SOURCE: 1554 cub cadet stalls out when you turn mower deck
Seat switch - or the wiring to it - is bad.
Posted on May 08, 2010
  • 4 Answers
SOURCE: My cub cadet model 2066 cuts off after about 45
VAPOR LOCK. TRY NOT TIGHTENING THE CAP AND SEE IF STILL CUTS OUT.
Posted on Jul 02, 2010
  • 760 Answers
SOURCE: cub cadet 1050 fuel problem
Clean, gas tank, fuel filter (replace) fuel shut off valve, and then clean carb, starting with bowl.
Posted on Jul 23, 2010
My mower Cub Cadet GT 1554 stopped moving. I found a plastic thing that looks like abfan on the ground
The transaxle (transmission) has a fan fastened to the drive pulley. It is possible that you belt has jumped off of the pulley on the transaxle and this broke the fan.
Jul 05, 2017 | Cub Cadet Garden
My Cub Cadet just got serviced for another 500 bucks and is doing the same thing as last year. Ran it all day then it starts to sputter and stalls. Model GT 1554 HELP!
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
May 25, 2015 | Cub Cadet Garden
Wh;y does my cub cadet 1554 tractor mower lose power when engaged?
  • Does deck turn freely? Check and be sure mowing deck is not jammed or bad bearing etc. If nothing is wrong with deck, then check fuel filter, air cleaner element, dirty fuel system, bad gas, water in fuel, restricted fuel flow. Lack of fuel will cause engine to have lack power.
Aug 15, 2014 | Cub Cadet Garden
Cub cadet 1554
Is there anything wound around the motor shaft? If its belt driven is the belt loose or tensioner bad?
Aug 15, 2014 | Garden
Loses power while mowing
that wont cause your mower problem i think you have a dirty carb and fuel filter clean the fuel tank to put new gas from clean can in but to check charg system get voltmeter start engine let it run un hook positve side of battery put the red led of voltmeter on positive side and the black led to the negative side of battery and see how many volts produce 12 to 13.5 good below that replace regulator above that replace regulator
Jun 18, 2013 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
50 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
