Question about Dell Inspiron 9400 Notebook
Problems with Dell Inspiron 9400 Video Memory conflict -
Please help resolve the following error message: -
Extended Test - Service Tag FBDZ2BX
Error Code 5300:0119
Msg. Detected a failure which writing and reading video memory. Video Mode 4h(320x2004) ADDRESS B8044h, expected to read FFFFFFFFh bu read FFFFFFEFh instead, The given error code and message can be used by Dell Tech Support to help diagnose the problem.
I thought the problem may have been caused by an application i recently downloaded, Freevideo converter YouTube to Ipod that i have since removed.
Dell Hong Kong unwilling to help because warranty expired and without $$$ up front. Laptop is just 22 months old, now only runs on "safe mode". My search through internet reveals that this is one major problem with the inspiron 9400 that I am beginning to hate. Please help.
  • normax1812 Mar 27, 2008
    Dear Iqbal,
    Thank you, Dell ought to learn from you. I will certainly try as per your suggestion.
    normax
  • asiegypt Dec 12, 2008
    i have videa memory test error code 5300:0119, how can i fix this problem
    thanks
This solution is totally incorrect. He is having the problem that many of us face with the GeForce Go 7900 GS and the Inspiron 9400. There is a known issue with eventual overheating and the video card going bad. This is specific to the single-pipeline chip, in which their is a new dual-pipeline style that fixes the cooling/overheating issue that eventually fries the video chip. Dell has not 100% took ownership of this. I am on my fourth fried video card (thank god for the 3-year warranty I got) in which they have previously replaced with the single-pipeline style. This time they are finally replacing the laptop with either a new Inspiron 9400 (better be dual-pipeline chip) or a NEW equivalent laptop.
Posted on Nov 07, 2008
This error is common to the 9400 and m1710 and is a GPU/video error due to thermal stress on the chip the expansion and lead free solder is the cause. No fix even a replacement will fail in time used cards are likely to fail even dell only offers 90 days warranty. The problem is a bios error in that the fans kick in too late. Dell are fully aware of this error yet the bios in the m1710 is 4 years old.
Posted on Mar 22, 2011
I have reformat my inspiron 9400 with window XP sp2 the problem is the sound where i have tried to download from Dell website but still not workout can you pls help me to resolve this problem
Posted on Dec 01, 2008
  • 655 Answers
Actually this type of error messages raised by OS when any program try to read some data from absurt memory addresses. This makes conflict to OS and OS gives this type of error.
You can fix this problem in many ways. Here are some, choose one which is applicable to you or which one you can do easily:
1). Boot your PC in Command prompt Only and type SCANREG and press enter at command prompt. e.i.
C:\WINDOWS>SCANREG
Follow the on screen instructions. When it displays a list of dates when your window was loaded successfully, select the date before the date when you have installed that erroneous software.
It will restore all the settings as it was on that day.
2). If you had made any restore point in windows, then you can make windows recovery. To do this Boot in safe mode goto Start->Programms ->Accessories -> System -> System Restore
and follow the on screen instructions.
3). Factory restore from CD/HDD. Your system might be shiped with recovery CD/DVD use this to restore at factory setting. BUT USING THIS OPTION YOU WILL LOST EVERY THINGS WHICH YOU HAVE INSTALLED OR COPIED AFTER FIRST BOOT. SO PLEASE TAKE ALL BACKUP BEFORE ATTEMPTING THIS OPTION.
If any problem occurs just Ask me.
Good Luck
iqbal
Posted on Mar 27, 2008
I have a dell inspiron 17r the battery does not charge I have tried multiple chargers. but dont have another battery yet. I ran the test using FN and Power at the end of the extended test i got error
go to www. dell.com and get support from via chat, and download the dell diagnostic ONLINE, and see if the problem is finally the adapter or the battery. Give your service tag.
God bless you
Oct 16, 2012 | Dell Inspiron 17R Laptop Computer (Intel...
No sound speakers and headphone dell inspiron 9400
First, check that the audio is not muted, either via any hardware switch/button, or via software.
If not, I'd download and reinstall the sound card drivers for your notebook here:
http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection
you will need to select your model, or put in your service tag (on the bottom of your notebook) and then look for the driver under audio in the list.
from memory the first audio file should be the one you are after.
click on download, on the right hand side.
once downloaded, run and install software, then restart the computer.
Hope this info helps.
May 21, 2012 | Dell Inspiron 9400 Notebook
Need a password for dell inspiron 9400 service tag #HNCKCC1-595B
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
May 10, 2012 | Dell Inspiron 9400 Notebook
I have a Del Inspiron 9400 laptop (Vista). Having problems playing DVDs message reads "compatible decoder not installed". I can however convert dvd's through Handbrake then play converted videos on the...
The common advice is to go to cyberlink, pay and then download windvd, however there is a better option.
Download VLC which is a tremendous video player (plays every video format) that will play DVDs. It's free too :-)
Here you go: http://www.videolan.org/vlc/
Jul 26, 2010 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Your video card memory went bad, has to be replaced,
You have to have it serviced, you can take it to Best Buy to have it serviced if you don't want to pay the premium from the vender!
Dec 21, 2008 | Computers & Internet
Dell Inspiron 9400 Notebook Logo
2,324 people viewed this question
Alun Cox
