Question about Whirlpool GEW9250 Electric Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
  • Whirlpool Master
  • 43,501 Answers
If you have a gas dryerMy Whirlpool Imperial electric dryer runs but - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_notMy Whirlpool Imperial electric dryer runs but - 2_bing.gif/>If your dryer2_bing.gif is electric2_bing.gif..
There could My Whirlpool Imperial electric dryer runs but - 2_bing.gifr of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gifTroubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
My whirlpool imperial electric dryer wont heat up
It's either the fuse, heating element, thermal cut-off or thermostat
May 21, 2012 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
    It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
    Feb 12, 2011 | Dryers
    No heat whirlpool electric dryer imperial 70 1986 vintage
    replace cut off switch fuse at the top of heater box
    May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool Imperial Electric Dryer wont heat up
    Check the following to address this issue.
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Heating element
    A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
    3. Thermal fuse
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Whirlpool Dryer not heating
    There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
    1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
    2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
    Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
    Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
    Dryer runs but will not heat. Replaced fuse and
    your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
    Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
    Whirlpool super cap. electric dryer imperial
    element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
    Apr 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool GEW9250 Electric Dryer Logo
    165 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
