Question about Dynasty DGRSC 30 Gas Kitchen Range
When I turn on the oven to bake, nothing happens.
The broiler works. The burners work. All the lights work. But nothing happens when I turn the oven on to bake.
  • 2,605 Answers
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not at all ) but yet not reach the needed value to open the valve consistently nor adequately, hence the need to replace the bake ignitor. Other times, like yours, it won't glow at all, but manifest in the same end result...no flame. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 Try places like repairclinic.com, searspartsdirect.com, APwagner.com etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
Posted on May 06, 2010
Jennair gas oven. lower burner won't light, i.e.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
heatman101
Mar 30, 2010 | Ovens
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Oven will not light but broiler works
More than likely the igniter for the bake manifold has become weak over time and now needs to be replaced. Each burner manifold in the oven has a separate igniter. That's why your broiler still works. Due to the frequency of use, the bake igniter wears out faster and may require replacement more often. The following link explains a little theory on how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Oven not working
check its fuses, might be one of them has blown/ open.
Jul 30, 2008 | GE JBP71 Electric Kitchen Range
Dynasty DGRSC 30 Gas Kitchen Range Logo
499 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
