Question about Phoenix Gold Titanium 800.1 Car Audio Amplifier
Need optimum settings or manual for PG Octane R 8.0:1 amp
Does anyone know the optimum settings or where I can download the manual?
2 Suggested Answers
  • 9 Answers
SOURCE: amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
Posted on Jun 02, 2009
How use pa system
All the 8 ohm's means is that you need to use an 8 ohm speaker for optimum performance. That is what the radio is set up for. Most small PA speakers for auto etc, are 8 ohm's.
Jun 02, 2014 | Uniden Radio Communications
Been using 87 octane in '02 maxima for 1yr. have replaced oxy & nkock sensors. Is this due to low octane?
Ok the 2002 Maxima 3.5 requires premium fuel 91 octane. According to the owners manual for optimum performance use 91 octane, you can use 87 octane unless you get pinging sounds. Sounds like you just need to use the proper octane. Occasionally I will run regular 87 and can really feel a loss of power. When I use 91 octane the car is a rocket ship.
Sep 19, 2012 | 2002 Nissan Maxima
How can I make the focus ring work on my casio exilim ex f1?
The manual (pg 43) says that each time you press the FOCUS button, it will advance between Auto (AF), Macro (Flower), Infinity (Sideways 8) and Manual (MF). You can use the < or > keys to focus , or the ring if set up as described below:
Next, the focus ring can be programmed (pg 85) by pressing [REC] -> [MENU] -> [REC Tab] -> [Ring Setup]. Choose "CS fps" for Continuous Shutter Speed (pg 46), "Zoom" (pg 40), "Focus" (pg 43), or "Off" for no function at all.
You can download your manual here.
I f this was helpful, please rate it 4 thumbs up. Thanks!
Sep 22, 2011 | Casio Exilim Pro EX-F1 Digital Camera
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
No problem. What is the step by step instructions
go here
http://support.medea.co.uk/download.php?FLIB=1&id=8
this is a
Refill Instructions for -
Canon PG-37/PG-40/PG-50
CL-38/CL-41/CL-51
as bdf file
i hope that helps
Nov 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Phoenix Gold Octane R 15:0.1
Go take a look at www.rodinaudio.com; go to contact info and call PG direct.
Aug 14, 2008 | Legacy 2CH 800W AMP Car Audio Amplifier
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
Aug 14, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Amp connection
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Phoenix Gold Titanium 800.1 Car Audio Amplifier Logo
54 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
