Question about Motorola Mobility Hint QA30 Cell Phone
Botton are sticking - Motorola Mobility Hint QA30 Cell Phone
  • 190 Answers
Try to blow up with a hair dryer, make sure is not hot air.
otherwise you have to unscrew the plate, clean it.
and screw back
Posted on May 12, 2010
My 2nd machine and same problem the start botton falls into the machine its a push botton 2months out off gareintee
you can remove the panel and look inside, the button is usually spring loaded. and u may be able to work with it to fix it? many times a build up of soap and softner can cause sticking keys
Mar 26, 2015 | Washing Machines
The remote is not communicating with the AC, Both function but wont get along. Is there any way to reset the remote??
try to use the bottons on the a/c unit first if it functioning well,if it is good then the culprit is your remote control needs to repair.some models also are having tiny holes ,some at the back and some are at on front.dont use any metallic materials to switch the miniaturised built in bottons instead use some made of woods and coconut stem and plastic forms stick to resetting the remote
Apr 16, 2014 | Danby DPAC13009 Air Conditioner
1995 riviera buick horn want stop blowing and some times blow fuses
Faulty horn relay.sounds like relay is sticking or horn botton is stuck.
Jun 06, 2012 | Buick Riviera Cars & Trucks
My dvd driver wont open when i push the botton. what is the problem?
it might just be jammed there is a small hole in the front of it stick a paper clip into hole and it will open the dvd manually
Jul 09, 2011 | HP Computers & Internet
Cannot eject disc door will not open
It means the eject botton is not functioning, maybe the botton is not contacting the appropriate function.
Try and open My Computer or Computer from START botton and then right click on the Disc-R to select eject and you will find it open immediately.
Jun 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Power display screen is saying to press the clock botton but i an not getting any respond
THE BUTTONS ON MICOWAVE IS STICKING TRY PUTING A MILD SALUTION ON BUTTONS.
Feb 15, 2011 | Kenmore 80412 Microwave Oven
When i press select botton my psp hung up
Please check your key pad (select button for sticked ). Replace the key pad if needed
Jan 24, 2011 | Sony PlayStation Portable (PSP) Console
My overdrive light is constantly flashing can anyone please help
the shift stick has a botton at the very top that is the switch to the overdrive. sometimes you press it accidently when u shift. when the light is flashing u cant turn it off w this switch u have to turn off the truck and when u turn it back on make sure u dont press the botton when u shift again
Jul 03, 2009 | 1997 Ford Explorer AWD
Starting botton does not work
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 25, 2009 | Whirlpool Dryers
Motorola Mobility Hint QA30 Cell Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
