Question about LG WM-2277HW Front Load Washer
LG front load washer
Doesn't rinse clothes it states OE on the display screen
  • 1,543 Answers
That's actually DE (Drain Error). Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
Posted on May 06, 2010
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
OE CODE ON LG FRONT LOAD WASHER...
Check for blockage,filters hose pump problem?
Jul 30, 2014 | LG WM2487HWMA Front Load Stacked Washer /...
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Machine gets stuck in rinse cycle - sometimes gets OE code sometimes not.
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | LG WM2455 Front Load Washer
My machine just stopped during the cycle, and displayed 'OE'. What does this mean? Why did it do it?
The OE is an overload error. Try removing some clothes. If that does not work you could try unplugging the machine. I have a manual you might want to look through. LG washer manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 19, 2010 | LG WM-2032H Front Load Washer
I'm getting an OE error on my LG washer diplay
You are likely using the wrong kind of detergent and the suds are not being washed away.
Use high-efficiency detergent and/or lessen the amount of detergent you are using.
Jun 05, 2009 | LG WM2487H Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
168 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
